I'm currently looking at a French fob watch, and I've noticed what I can only describe as a 'cloudy' part of the crystal, as seen in the pic.
I've tried buffing this off with Windowlene, and then with (gasp!) acetone, but neither of these seems to have made an improvement.
This situation is new to me, I've not seen anything like this before. Am I in for a replacement crystal or how can I remove this, please? - I'm not really sure that this is something that is going to buff out as it doesn't exactly look like a a scratch and the area is not centred on the crystal?  ...
TIA
Ian
It almost looks like it has been stained. It depends how deep this is. Some on here have had success in polishing out scratches. However I am not a patient person so unless imperfections are minor I just change the crystal.
Hi There are propriatry  (polywatch)pastes for polishing watch crystals but I use Automotive chrome cleaner (Autosolvol) its mild enough and polishes ok takes a bit of elbo grease as does any polishing.
I use Simichrome which does a good job, just make sure the imperfection is on the outside, I spent ages the other day trying to polish out a blemish like yours only to find it was on the inside of the crystal, no idea how it got there though.
I use Abenaqui scouring paste (for kitchen cleaning) on a papertowel.  If it's a deep imperfection, a bit of very fine wet or dry paper speeds it all up.
Shane
Edited by Shane
If that is a glass crystal, then the crystal is probably "etched". A sticker or or something else that was slightly acidic was sitting against it for a long time, perhaps?
The way to get rid of that on a glass crystal is to polish with cerium oxide, I've seen a suggestion of using a piece of dowel rod to hold the cerium oxide paste (at the end). Supposedly makes it easier to handle than using a cloth.
Abenaqui scouring paste (I'm sure there is something similar in your location) uses feldspar which has a Mohs Hardness of 6 and works quite well on glass (if you are patient) and plastic crystals.  Glass has a Mohs Hardness number from 5.5 to 7, depending on the glass.  Cerium oxide was listed on the chart I found at 7, which will work faster but is more expensive and less available were I am.
I have used the piece of wood trick before but not on crystals (should still work).  The abrasive gets embedded into the wood and continues to cut rather than getting lost somewhere in the cloth.  Just make sure you average all of your polishing out across the crystal, otherwise you will see waviness through the glass.
Good luck.
Shane
I also use autosol. It was mentioned in a de carle book. I Have tried other things as well, bicarbonate powder not as effective  and also eucryl toothpowder which does actually work ok. But the Autosol is by far the best and is very comparable to polywatch, in fact i couldnt tell the difference.  I start with 600 grade wet and dry depending on how deep the scratches then 200 grit increments up to 2000 and then finish with Autosol. A crystal generally takes about 20 mins to half an hour depending how bad the scratches.
    • After cleaning up the pivots, I made bushes on the lathe. At this point I've pressed in 6 bushes (3 sets) and the wheels turn smooth. What I can also tell you, is that I'm not looking forward to final assembly. Getting the pivots aligned seems to get exponentially more difficult with each wheel that is added.
    • Islands are interesting places to live depending upon their size and other factors. This is a bigger island and it has a bridge to get there at least on one end. It's also big enough that you don't have to go someplace else to get things typically. It can be a problem if you get a job in Seattle though. Yes I've known of people who commuted from the island to Seattle for a job and I don't quite remember how many hours it took but it took a long time. So basically islands are nice if you don't have to leave very often.
    • Thanks @JohnR725! Everything you say makes a lot of sense and is encouraging to read.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
    • That Island looks pretty good on the pics I found. Must be nice to live there. Welcome! Are there many watchmakers over there?
