Hello, I am new here
jeet
Hi,
I am mechanical watch enthusiast, who is trying to fix my wall clock. In past I have learnt to repair wrist watches by breaking my dad's watch in the process of learning. I am fairly good at repairing stuffs and in general love repairing anything and everything from electronic/electrical/kids cloths/my car/bike... if its broken, I will repair it.
I am currently trying work on a Hermel wall clock which has a pendulum with escape wheel. I  bought it from a car boot and it worked for 7 years before stopping. I have taken out the mechanism and gave it a wash and re-oiled it. But unfortunately the pendulum stops after few mins of running it. To me it looks like that the escape wheel is not able to provide the required feedback to pendulum to keep ticking. but not sure of how to determine that the escape wheel if faulty. I did try to adjust the pendulum swing making sure it swings equal distance both way from dead position, but it still doesn't work. Any suggestions please.
Regards,
Jeet
Hello and welcome to the forum.  The question is how did you wash it!  In washing it you may have removed some gunk from a worn pivot hole which is now causing binding of the pivot or the wheel. The only way of proving all is ok is to dismantle the clock. First let down the power of the mainsprings befor doing anything then take plenty of pictures and make notes while dismantling so as to provide a viable return path during assembly.  Failure of the clock could be due to many things,  clock out of beat, faulty/worn pallet, worn escapewheel, worn pivots worn pivot brearings, general dirt/grime in pinnions, dirty and sticky mainspring or even broken mainspring.  For further help can you post a picture of the clock front and back with dial removed and also the model number on the back plate should be somthing like   (130-020).    Cheers for now
Thank you for your introduction and welcome to this friendly forum.
We all look forward to your contributions and continued involvement.
Please put you questions about your clock in the clock section and add photos. Then I should be able to help you.
Thanks for the warm welcome. I was quite overwhelmed by the first look of mechanism. I had experience of a less complicated one (no chimes) and struggle to put the individual wheel back as you know all are to be aligned perfectly to individual pivot bearings. So I took a short cut and used white sprit in a big bowl to wash the entire mechanism. I drained it fully (as much I am aware of) and then re-oiled it.
341-021 Hermle wall clock
1. The spring is working: I removed the pallet mechanism that controls the escape wheel, and used finger to stop escape wheel, wound the key, the escape wheel spun till the whole spring was unwound.
2. Is the time between tic and toc exactly the same as between toc and tic : This I am not entirely sure off, wasn't sure why this would have changed. I tried the basic way of visual checking but I might be totally wrong.
With my thread and stone arrangement, the clock keep ticking so my guess is that mechanically its all fine. Can it be just down to the beat?
Regards,
Jeet
Edited by jeet
It isn't going to work properly with that stone. I don't see the suspension spring? You need that and the correct pendulum. The leader is also missing. All parts should be oiled I always recommend Windels clock oil.  Do you have these parts or are they missing?
Thanks, for the response. I have all these parts; as I didn't had a proper arrangement to suspend the open mechanism, I am using the stone and thread, and the clock is ticking for more than an hour. Its ticking fast as its not a proper length pendulum, but it's ticking. But the moment I assemble back with the proper pendulum and parts it stops. Any suggestion on how I can properly adjust the beats.
The way it stops is pendulum slows down and then suddenly stops as if, it is stuck in some weird position between the teeth.
as you suggested earlier I have posted the query in the clock section
That is nice to know that you have all the parts. It is most likely the clock is not in beat, it needs to have an even tick tok. The green arrow pointing to the crutch is friction tight. With all the parts assembled and the pendulum swing the pendulum lightly if it sounds out of beat move the  crutch a little  one way until you hear  an even tick if it sounds odd move the other way it is a trial and error. This is a set up that needs to be done with all clocks that have a pendulum.
Hi  I should make up a board as a stand and fit the clock mech to it and fit the leader suspension and pendulum as setting it up like it is is nigh on impossible.,   all that is required is an L shaped board  with 4 holes to accomodate the movement  clamped to the bench with enough clearance for the pendulum to swing. set the movement level (use spirit level) thsn listen to the beat. As OH said the crutch is friction fitted and able to be moved left or right. then adjust the pendulum for an even tick/tock. as
 Stopping in this position could be a depthing problem with the pallet and escapewheel  check the escapewheel teeth are good and have no burrs or are bent slightly it doesnt have to be much to stop a clock.
Thanks again to each and everyone for the support, so far so good. I have attached the pendulum and the clock is ticking steadily from last an hour or so. Is there any reason that it might not do that once I have installed it in the box, as that was my experience from last evening.
Update: I have it now running for few days and all good. Had to adjust the chimes with trial and error, and all good. I am encouraged and feel confident to take up a new project, as I now know that I have a very helpful support group if I am stuck. Thanks again each and everyone of you. I am feeling confident 🙂
    • Personally I would salvage the missing screws from some donor movement.  I also bought a random selection of screws "Assortment of Stainless Steel Watch Screws" for next to nothing.  As for using an Alum solution - I had great success with that removing a rusted stem from a stainless steel crown.  The best piece of advice I read on doing that was to keep the solution warm so that the reaction didn't take weeks!  I did it in a couple of hours with the solution in jam jar and the jam jar in a saucepan full of water which I left on an induction hob maintaining about 60C in the Alum solution.
    • I decided that it was time to tackle the piece that I'd set aside as my first project. The subject in question is a Gruen Veri-Thin pocket watch.  It winds and "runs".  On the time grapher, it has reasonable amplitude (240 or so depending on the position), but was loosing close to a minute a day.  The stem also has the annoying tendency to just come out when pulled, which makes it super hard to set the thing.  As with many things this one started sideways and just got more so.  I was able to overcome the mangled "tab" on the back case cover (a well placed, very sharp knife enabled me to get in when I couldn't get a purchase on the mangled tab with a case knife.)   I was then sort of shocked to find that one side of the dial was held down with some sort off tape or adhesive material as someone had broken the dial foot screw on that side and left the broken screw in the mail plate. The loose stem does in fact seem to have been a poorly tightened setting lever screw, but I'm afraid there may still be gremlins in the keyless works.  While I was able to get the stem to stay in by putting everything in the right place and tightening the setting lever screw (before I took it all apart for cleaning and inspection), it just didn't seem to all sit right. The final gremlin showed up when I was taking off the lower cap stones for the balance and escape wheel (yes the Gruen 380 seems to have a cape jewel on the escape wheel).  The balance stone came off fine (but that in fact is the smallest screw I've ever seen.  When I turned the movement around to get the one off the escape wheel setting, I found that the screw head had been mostly sheared off.  After some reading and looking at what I had, I decided to try and tease what was left of the screw out of the hole by nudging what was left with the corner of my smallest screwdriver.  After 20 minutes or so, I was able to get the remains of that screw out. The picture I'm including of the disassembled movement was taken before I got the second cap stone off, so in the picture, it's still attached to the main plate (for those looking carefully, you'll only see the one cap setting in the pic.) Now I'm left with: A broken dial screw inside the main plate that needs to come out A broken cap stone retention screw that I have in my parts tray, but that is strictly useless and needs to be replaced. The need to get another dial foot screw I'm contemplating solving the first problem by soaking the main plate in an alum solution.  I think the main plate is brass and shouldn't be affected, but I have not been able to confirm.  This seems like the easiest option as I can't really access both sides of the screw to use the pricey Bergeon tool (which I don't fancy buying unless I have to.) I have located a couple of donor movements and have questions out about whether or not the include the dial foot screw and prompting for pictures of the dial side so  evaluate the cap stone settings.  I've also found that a supplier in this country does have the cap stone settings, but isn't overly clear about whether the screws are included. Are these the types of things that one can scavenge out of assortments or is it best to just grab one of the donors assuming that they look like they have what I need?
    • I visited this place last year just before they closed their counter service - amazing shop (filled from floor to ceiling!) and the guy that was working there was really knowledgeable and helpful!. Their website isn't as good as Cousins but I understand that if you fill out the contact form they have stuff that isn't on the site. https://gleave.london/mineral-flat-bottom-domed/
