Hello
Novice here. And thanks in advance for any advice.
Recently entered the world of watch making, and since I know little of nothing, I have a question.
I decided to start with pocket watches, and I have an old Waltham pocket watch I am working on.
It is running super slow (around -250s/d with the regulator in the middle)
The two balance wheel timing screws are turned all the way out. And the main spring is apparently gunked up. It winds stiff, and unwinds like it is caked with old grease.
So, I am going to tear it all the way down for a thorough cleaning.
But the question is - what happens when I adjust the regulator.
I had the regulator maxed out to the + side so running about -40s/d.
But when I barely move the regulator, IE just nudge it, The s/d may go to +200 for a short while then settle back down.
I have other pocket watches that don't jump to this extreme.
So, I am wondering if this is a problem with the regulator pins or something else?
Whatever strange behavior happens in its present state means little or nothing.
Only after it has been cleaned to perfection, all parts inspected and found to be good at least, then put back and lubricated correctly, you will be able to make meaningful observations about its performance. And It will be better that you use a timegrapher to make calls at that point.
BTW if you really care about this watch it would bw better that you practice first on something else of no value whastoever, especially about hairspring and balance handling.
Welcome to WRT forum.
Timegrapher results be nice.
 Release barrel power through the click so oscilator wont run, then hairspring should not come to contact with neither the boot nor pin, as you move the regulator arm throughout the entire terminal curve.
The transiant state you see can be due to such a contact momentarily throwing the oscilator out of beat.
    • Thanks everyone for your helpful replies. I think between us we’ve worked out what’s going on. Next job is to have a proper look at this great wheel assembly, see if I can remove the clip and the friction fit pinion, give the bits a good clean, then put it back together with a bit of blue grease. I’ll also get the pallet fork under the microscope to see if it’s ok or been damaged.
    • The cannon pinion (be it conventional style or what you see in this movement) should slip on its arbour so the hands can be set independently without affecting the gear train.  If there is too much friction between the cannon pinion and the second wheel, turning the hands to set them backwards can sometimes force the escape wheel teeth to overrun the pallet stones, creating the behaviour you describe. The train is running in reverse when this happens.  This can often chip the pallet stones. I’d say at least half of the watches I’ve inspected with very tight cannon pinions had chipped pallet stones. Hopefully this isn’t the case with your watch.  I’m not familiar with this movement but you need to get the friction in the cannon pinion adjusted correctly.  Hope this helps, Mark
    • Pallet fork was in. I’d had the movement running ok, and only removed the balance to flip it over and install the keyless works and date mechanism. The pallet fork wasn’t locking the gear train when hand setting - it was oscillating as the escape wheel rotated. This may have been in one direction only - can’t remember.
    • Hi   Find attached parts/repair notes for the JLC 911,  might be useful. JLC_JLC 910, 911.pdf JLC_JLC 910, 911 Repair Notes.pdf
    • Hello and welcome to the forum Dan. Used to know Middlesboro quite well, that was twenty years plus ago. Attached a little reading to get you started. TZIllustratedGlossary.pdf
