Single Speed Or Variable Speed Polishing Machine
DJT2
Hi guys, I'm in the market to buy my first polishing machine. I'm wondering if there are any recommendations? I'd say I'd be comfortable with spending upto £275. I'm just getting a little confused on what spec would be the most beneficial for me. Ie.. Do I require 8", 1/2hp, 550watt, variable speed etc. Any help or advice would be welcome.
No need to spend a lot of money buy the likes of this http://www.screwfix.com/p/scheppach-bg150-bench-grinder-150mm-240v/28349?kpid=28349&cm_mmc=Google-_-Product%20Listing%20Ads-_-Sales%20Tracking-_-sales%20tracking%20url&kpid=28349&cm_mmc=Google-_-Shopping%20-%20Power%20Tools-_-Shopping%20-%20Power%20Tools&gclid=CPX70uKA88UCFSkGwwod2XUA9gand fit with a set of these http://www.metalpolishingsupplies.co.uk/bench-grinder-polishing-spindle-adapter-set-1-2-12-5mm/?gclid=CNLNup2B88UCFQKK2wodm30AfQ
I have been using this setup for polishing metal for many years now, but I still prefer to refinish watches by hand to ensure there is no damage to edges and sharp profiles. Only very occasionally will I use a small buff on my Dremel.
Unless you are going to be polishing plastic, you don't really need a variable speed machine.
PS. I'm not saying to buy the above, they are only to illustrate the type of polishing system I use.
I must admit I've seen you mention that you generally hand polish watches & as I've only ever polished the sideboard before, I've looked for videos on you tube for hand polishing watches & can't find any. The only stuff I can find is with machine polishing. Hence getting the machine.
I just have finished modifying dual table grinder from Lidl to adopt it as a polishing machine. It seems to be solid and not very expensive. Im not doing much polishing so for my needs its enough. I added speed control module to it (DIY kit for speed control from one of the shops with electronic stuff, I had to solder but that was fun). Module fit inside case of grinder and only change I had to do was drilling hole for knob for changing speed). I used connectors to put it into circuit so it can be back to original state at any moment, just unplug module and pug it back as it was. It runs quite nice, 200W its enough power, motor seems to run smooth and don't need any maintenance. I can use polishing wheel sized up to fi 15-20cm, up 30mm wide. only problem was getting wheels with proper hole size as it accepts 13mm, so I have to use adapter from 20mm/13mm. All together cost was about 40$ for the device. I can post pictures when I get home.
btw. speed control may be needed if felt wheel is used - too much speed and it can give you burn marks on metal.
Edited by Rafal
Looking forward to seeing the pics. I was toying with trying the same thing, however I wasn't sure what size motor/watt & rpm I'd be looking for when purchasing.
Here are the pictures. I believe Cousins sell cone shafts which could be used to attach polishing wheels. This is first draft and I plan to make improvements :). From behind, just by power cable, you could see knob for speed control. That was the only sensible place for it.
post-1017-0-12164600-1433352419_thumb.jp
post-1017-0-02525700-1433352425_thumb.jp
Edited by Rafal
I'm with Geo, and pretty much have the same reference.
The following related videos may come in handy for you too on how to prep your wheels.
Put the kettle on, they are 70+ minutes (combined).
Edited by SSTEEL
https://www.youtube.com/watch?v=2jnJe2jANms
https://www.youtube.com/watch?v=YMuWrI-sCj8
I've watched them & they are really informative. I even looked at buying the exact same Ray Foster bench polisher that was in the video £350 but just can't justify it at the moment.
    • Hello people , this is maybe a question that the moderators can answer.  Can seperate posts be unmerged from each other. Sometimes posts are missed by others because of a continuation of them . Even when answering seperate people the posts are grouped together as one. Maybe it saves message board space ?
    • Just got these good quality diamond files from the bay for Just a fiver, we all love a bargain dont we. Brand names are J.K.Smit  and Triefus, two old diamond tool makers so not cheap crap.
    • Its a touch under ive just remeasured it and added a wrist shot. Unbelievably it was £13  plus 3 postage. You dont find watches that nice for that money every day of the week. Maybe removing the epilame in the oil region improves the purpose of it. We may know very soon as i emailed Episurf 4 hours ago to ask that exact question. 🤞they are happy to provide an answer for us. How do you fancy trying a stearic acid vapour treatment experiment  H .  Shall i have a go this afternoon ? Stearic acid experiment underway,  its started to melt at around  65° C. The idea is to find a large cap jewel to suspend over the vapour release.
    • That's the size of my grandfather's Ernest Borel watch. Definitely not a lady's watch! 👍
    • Thanks H It does have a big crown for the watch , it could be considered a ladies watch these days i guess, it measures 33mm case 36mm with that large crown 18mm lug space. A tad small for a guy of today, but still very wearable. The photo was deceptive so here it is adorning my 7 1/4 " wrist. It need some love to make it run better. The hair coils are touching so running a bit fast at the moment,  not caused by magnetism, and maybe just a clean and a service. The dtal is in fantastic shape.
