I was inspired by a post on the Watch Repair Lessons Facebook group showing a DIY watch bench. It's using a 62" Husky adjustable height desk with some added rails along the back and sides and a Vyco table mat on the desktop. My old setup was so cramped and jumbled together and now after getting rid of my old office desk, I have a lot more room to work and I can adjust the height of the desk to ideal. I'll eventually be adding some more drawers/tables along the sides for storage.
It was (somewhat) cost effective with the desk costing $199 (on sale), the Vyco mat $75 (free shipping), and the rails just some pine from my local lumber yard for $14.
Edited by GuyMontag
  • Like 9
Very nice Guy. What scope are you using please?
It's an Eakins from Aliexpress:
https://www.aliexpress.com/item/2251832821477621.html?spm=a2g0s.12269583.0.0.45671741T7tstH
I really like it, it has fantastic image quality. I have noticed that the top horizontal bar on the boom stand is starting to flake off bits of what look like chrome. That's kind of a bummer. The camera it came with is only OK, it gets the job done but it has limited dynamic range and is overly contrasty. I'm a photographer and have some DSLR's and mirrorless cameras that I want try instead but I'm not sure what adapters I need...
  • 9 months later...
How are you liking that adjustable workbench?  I was looking at Husky adjustable that has two drawers to it.
https://www.homedepot.com/s/1003951491?NCNI-5
Facing a window so you have natural light is good. Are you working with your scope all the time and not using an eye  glass? Not sure about the colour you have for flooring.
I really like the bench. I thought I would use the height adjustment more but in the end I tend to keep it at a height that is comfortable and then when I use the scope I just raise the chair as that is faster than lowering the desk.
I use the scope a lot. I started using it for about 100% of the reassembly but I tend to use a 4x mag visor for disassembly.  Yes, the floor color isn't ideal but it's better than the carpet that was present when we moved in 🙂
    • One of the problems we would have with a watchmaker's lathe is they were made over considerable span of time and manufacturing in the early days probably wasn't as good as it was today. Then if you look at the older catalogs typically it was just the head a few collets and something to rest graver on. So basically a basic lathe with over time things acquired but acquired things may or may not fit. Order today you purchase a used lathe that all kinds of nifty bits and pieces from a seller that acquired from? This would come back to that the basic watchmaker's lathe was used for basic watchmaking like turning things with a hand graver. Then limited indexing is fine because you can make things like stems Which don't need a whole bunch indexing   In the link above the word vector is mentioned and at the link below you can purchase one. Then of course you're going to need the motor that's a little bit extra for the price. https://www.hswalsh.com/product/lathe-vector-watchmakers-48-collets-hl11. That you're going to need some bonus parts like these found this picture online show the classic way of classic gear cutting.   The lathe could have a much bigger indexing disk but it has to be mounted close to the edge. Otherwise you're going to have a whole bunch of smaller disks like this which I think has notches rather than holes. Then as wonderful as these pictures look actually cutting a gear with this is not entirely fun. Look at all is belts all pulling on things and this is a watchmaker's lathe lightweight with lots of bits and pieces attached. It would make more sense if you actually cut a gear with something like this and it tends to be it's not really the best way to do it looks nice on paper but it is not the best way to go. Reality for cutting watch parts would be a bigger machine is much better. Than getting rid of all those belts and pulleys also good. Here is an interesting channel I would've liked of found a different video but this was nice and short if you look at his video as he uses a stepping motor and worm gear assembly for the indexing plate. In this particular video it gets attached to the lathe at about one minute and seven seconds and it looks like it's hiding looks like he has a Sherline. I do know he's had other stuff you'll just have to go through his videos to find it. Then at about one minute and 22 seconds you find out if you set up things appropriately. It's always bad we end up with half a tooth at the very end. Then you will note big lathe yes he's getting a big gear but you could easily cut a watch gear with the setup. And it definitely way more stable than a watchmaker's lathe.         Oh here's a company they been in business since 1911 http://www.fwderbyshireinc.com/
