American barrel arbor
Willow
Just stripped down a William and Gilbert 1886 mantle clock, my first American clock for cleaning and by gosh does it need cleaning not come across one this dirty before ,though i dare say a lot of you have and worse.
Anyway my question is how to get the arbor out, the count wheel is riveted to the barrel, on both arbors the rachet wheel won't budge don't want to force anything in case i damage something and just hope the barrels will go on my springwinder ok. Thanks everyone
Yes the ratchet looks like its on a square but won't pull off and i don't want to force it in case i damage something, and the count wheel is riveted on will give it a good clean and have another look.
I am going to give it a clean and try the brute strength method🤣
54 minutes ago, oldhippy said:
I'm sure if you put a couple of good man enough screwdrivers under the ratchet wheel it will come off. What a crazy design.
Yippee😂 finally got the arbor out and ratchet off after someone surgested supporting ratchet and giving the arbor a few taps, well after a few whacks rachet popped off and arbor came out job done seems like alot haven't seen this type before even are friends across the pond thanks everyone for your input
37 minutes ago, oldhippy said:
That is good news. What are you going to clean it with?
I have gave a first wash in warm water and liquid to get some of the oil off yesterday and now i have the mainspring out i will do the same with the barrel etc accept the spring then everything in parrafin then final wash.
Hi just some advice not about this clock but one i am thinking of buying. Didn't want to start a new thread for this,i am told it's German but that's all they know about the clock except their father had it for 38 years. Any Thoughts.
With out seeing the movement I can't really say. Its a strike, that top doesn't look right it looks more like the sort of thing you see on those German wall clocks which many confuse them with the proper Vienna wall clocks. Take that off and the case looks right.
Here is an example of the type of German wall clock.
Thanks for that oldhippy did ask them if she knew the makers name or if there was a trade mark on the movement all she knew was her father had it for 38 years and it's been stored away for a few years so she is having a clear out, thanks anyway Hi watchweasol that's it no photo of the movement she only wants £20 for it but then i have to pick it up from Leyland so i will probably give it amiss, thanks anyway
    • Ah so its you thats buying up all the DD calibres 🤨.
    • Hi Richard,  I keep buying CAL.59 movements to practice on 🙂 Not started yet though, I'm gathering tools and building my confidence to start.
    • Problem solved. For some bizarre reason, the hook on the wall of this barrel is not properly centered vertically, but is oddly high on the wall, maybe 3/4 up the way up. When replacing the mainspring, this caused the outer coil to be displaced upwards as well such that it protrudes out of the barrel and caused the barrel lid to not sit quite flush to the barrel. Since this is a motor barrel, the lid is actually the first wheel and inner coil tube/hook all in one piece, with no “snap down” action that would have made the problem more immediately obvious. Maybe with an older mainspring the spring’s end hole was enlarged such that this wasn’t an issue, but hard to say how it ever worked otherwise. Replacing the barrel with one from a different model 1900 where the hook was properly vertically centered allowed the lid to sit flush without mainspring interference and the friction problem went away. The bridge was far too thick to be bent (and isn’t), for those of you thinking that was the problem. Placing the removable arbor in the watch without the rest of the barrel proved that the proper end shake was actually there as long as the overall height of the assembled barrel was correct.
    • You are so true on a lot of what you have said. The main reason for changing the mainspring even if the old one is in good order is because it will take out your thinking that the mainspring is contributing to poor power output or fluctuations in amplitude. If a new spring is fitted that box can be crossed off as a potential source of a problem. Most customers are happy to pay the extra £20 for a new mainspring if they are already parting with a couple of hundred pounds for a service. A new spring is an investment for good running for the future.
    • According to Borel the 814 and 815 use the same escape wheel. It's kind of an oddball being so long.
