[Article]The British Watch And Clock Makers’ Guild Industry Action Fund
Yes, in my experience, 9415 must be applied very precisely so as not to impair the amplitude. It must be checked at a high magnification. Before realising this I got less than stellar results with 9415 and preferred and got better results with thin non-thixotropic oils.
Hello watchfolk. Something i have wondered about for a while but never looked into it and i bet its really obvious but I'm going to ask anyway. The two trace lines on a timegrapher provided they are seperated enough, how do we know which line relates to which stone ? I've always assumed that the top line is produced by the entry stone. -
Thanks @CYCLOPS and @RichardHarris123 I've not checked under the dial I'll and give you the update if present
I'm sure i tried the same with some cheap ones, its nigh impossible to get in to sharpen them , best bet is to buy new and look after them. -
I'd like one of those for my staking set. I bought a cheap roller remover, thinking I could just file the jaws down so that it worked well. It didn't, so I ended up buying the Bergeon version, which does work well. Though, as @Neverenoughwatches points out, you do have to be careful not to damage the roller of staff. Rollers are very soft and easily bent whilst trying to remove or refit.
