Lost Click !
....onto the question about the pinion ... these are pictures which as I say above suggests its a taper pin/arbor arrangement to my novice eye? is there a tutorial/lesson anywhere on removal and refitting?
Also this is a photo of the banking pins ... the one on the right is noticeably splayed?!! is this correct .... and if not how can it have happened?
45 minutes ago, watchweasol said:
Putting on my Deerstalker (sherlock Homes) I would bet it pinged on to your sleeve or chest and as you went for a coffee it fell off onto thr surface and repained there till you found it.   case closed
Good work dear Homes. Elementary, when you have eliminated  the impossible, whatever remains however improbable must then be possible as you often tell me. Ahem. Also a monster magnet and a million candle lume flashlight is very handy. I now need a the light thanks
3 hours ago, watchweasol said:
The banking pins have been bent to overcome a problem the previous repairer had do not straighten them up just leave as is untill the watch is running  then see how it goes, straigtening them now may give you problems later.
Would that fix have been made to solve more than one  issue ?
7 hours ago, watchweasol said:
Possible ,but it is guessing why it was done. Thats why its best to service the watch and check out the results. If it operates within its parmeters leave it alone if not investigate.
I was silly enough to almost start thinking it was the constant  tap of the pallet fork that bent them. But then decided that was impossible .
29 minutes ago, watchweasol said:
I was wondering if there is any detrimental effect to the watch having an out of beat balance. I've only ever got zero.zero once. Effecting time  is not that much of an issue, if a watch is as much 30 seconds out that's only 3.5 minutes a week, not many peoples schedule is that tight. And a once a week adjustment is no great shake. And a lot I assume will forget to wind their watch at least once a week anyway so there will be some time setting going on during that week. Would big errors cause an abnormal  wear on the balance pivot possibly
Am I right that this is a pin and arbor arrangement?
What is the process for refitting once disassembled bearing in mind that I do not yet have a staking set.
16 hours ago, watchweasol said:
As the lift angle is calculated from the balance swing it may have a direct inpact the site below explains the lift angle
https://r.search.yahoo.com/_ylt=AwrIS.WuUVhi5ycAIQJ3Bwx.;_ylu=Y29sbwMEcG9zAzIEdnRpZAMEc2VjA3Ny/RV=2/RE=1649984047/RO=10/RU=https%3a%2f%2fwahawatches.com%2fwatch-talk-whats-the
Hi  An out of beat watch,  depends on the error too far out and the watch will stop the further away from 0 will eventually affect the rate. Thats why when regulating a watch get the beat as near perfect as possinle then start the regultion.
The closer the beat the easier the watch starts from a standstill. Some I have need a gentle rotation to get them moving and stop too soon before the power has drained
Would bending the banking pins because Heath Robinson way of freeing up a locked impulse jewel ?
The bankings pretty certainly didn't leave the factory like that. The escapement would need to be checked to find out why the entry banking is so bent. A guess from afar: the exit stone has been replaced with a stone too long or moved out for some reason, which means the escapement wouldn't fully escape from the exit side as the fork was against the banking on the entry side. Moving the entry banking pin will allow it to escape, but now in addition to the extra lock on the exit side from the jewel being out too far, there is additional drop and total lock on the entry side. The watch probably runs, but amplitude will suffer very much.
I've been trying to find a clear description of the steps to checking and adjusting the lever escapement to share, but so far it's been old confusing texts or nothing. It's not that hard to understand or carry out the adjustments, but without a clear description very daunting. I actually know trained watchmakers from good schools who don't really understand it, so it's not just new/hobby folks who are in the dark. If I have time one of these days maybe I'll put something together. In the repair work I do I probably retouch the escapement on a third of the watches I see- it's an important thing to check and correct.
That would be extremely much appreciated! I'd even be willing to pay for it! Folks, please support this idea by liking @nickelsilver's post above!
Edited by VWatchie
no one appears to have noticed my question about the arbor pin arrangement which appears to be how the cannon Pinion is fitted?
I need to remove the centre wheel but only have experience of the standard cannon pinion arrangement.
I have found some threads describing knocking the pin through from the Pinion side releasing the wheel ... but no description so far on how to reassemble? Is the pinion simply pressed back down onto the arbor with tweezers, or is the process more involved?
Thanks for any input. 👍
Yes, knock it out. If the center wheel is jeweled at the bridge you want the bridge off, and support the center wheel in a hole in a bench block, or better, a staking tool when knocking out the pin. If not jeweled you can leave the bridge on, but still support it on a block with a hole to pass the pin. The pin will go down as far as the top of the cannon pinion, which should be plenty to pull off the CP and the pin out the rest of the way from the center wheel.
Going back, push in the pin, (this is with bridge on), support the large end of the pin on a block, and press down the cannon pinion. You may need to press quite hard, or use a staking tool with flat faced punch with hole to pass the pin to get the CP seated all the way.
I've seen Mark do the resetting of pallet jewels, it looks a very fiddly guessing game. I assume a lot of practise is needed
If done correctly there's no guessing at all- that's the thing, haha. But like I said, even trained (Swiss) watchmakers I've known approach it as a guessing game. Not all, but still surprising.
    • Hmmm you know when i said some damp might have caused the bubble originally hmmm 🤨
    • Are you all jerking my chain, I'm a yorkshireman £4.04 is too much 😆
    • [Myota2034] Custom simple quartz watch — PricewaterhouseCoopers On a very very different note, here is a watch from approximately 2000 when I was a Partner with PwC, Management Consulting. It was a simple “marketing watch” with a clever “vase of knowledge” that is subtly revealed on the dial as the second hand progresses. Clever for a simple watch!⌚️
    • I think someone else has though. Some where here using a modified perspex sheet. I may be wrong i may be right , i think it involved fitting the arbor to a pin vice. I dont have experience of the bergeon winders, are the handles not interchangeable ?
    • Never tried dial dots, i always considered them as a bit of a bodge.  You are adding something that was never intended to be there. I wonder how the adhesive reacts to any part of the movement, hot summer heat and i think things might turn sticky. Most adhesive backed stuff has a tendency to soften and slide around so it may spread, i have used a lot of so called sticks all adhesives in my industry that are just not up to the job. I suppose they get you out of a problem quickly, but how permanently might that be ? I would just explain to the owner that it may or may not work. WWs other ideas are a much more permanent solution but both have their risks . I've tried milling and dial feet replacements, hmm it was ok, ive heard of folk dimpling the face , so that needs care . And i have soldered a few times , all with good results but i am very careful and I practiced it a lot.
