Reverse Thread? No way right?
Feeling like a bonehead here, so bear with me. I have a ladies Bulova with 5AH movement. The first disassemble, broke off the ratchet wheel screw (A). Bummer, just ordered another movement, like $10.
Broke off barrel arbor screw again. Is there any possible way they reversed this ratchet wheel screw (A) on these little movements like crown wheel screw (B)? it makes no sense to me if they did. I would think they would unscrew themselves otherwise. I am just guessing these slowly got really tight when getting close to being over wound and the screw is just so small.
Order 3rd movement, cheeper than ordering little parts separate. Any tips this next go around?
3 minutes ago, grsnovi said:
Isn't the screw on the winding wheel (over the barrel) usually left-hand threaded?
B was reversed like most watches...my question is about A, that is above the main spring, and connects the ratchet wheel to the barrel arbor.
The secret is not to use brute force. When I'm unsure, I turn the screw a little both ways to see which way has less resistance.
I've come across watches with both the crown wheel and ratchet wheel with left hand threads. And yes, they do unwind themselves.
Are you holding down the ratchet wheel firm with a piece of pegwood, then unscrewing either clockwise or anti clockwise gently to see which one loosens it?
Also, you’re going to face serious issues lubricating the balance jewels. You have to release the balance wheel first.
Yes. I have come across several movements (recently a A Schild 984) where both the crown and ratchet wheel screws are reversed. Why? I don't know. Of course, I made a note on the pic for future reference.
As @HectorLooi says, if the screw seems tight, try turning it a little the other way. Even if it's not a reversed thread, this can help free the screw.
I suppose that was to save one tool change and one different screw at manufacturing.
    • I've bought brands like Citizen, Seiko, Titoni, Tissot, Roamer. Strange thing is many of them were using ST96 movements. I'm not sure if the ST96 is original to that model or whether it was a replacement movement.  All the watches with nice looking dials were obviously refurbished, after-market dials. And all of them had over-polished watchcases. Some of them had non-original hairsprings, rejewelled pallet forks, watch crystals that don't fit and glued in with a generous amount of glue. One of them was totally not working because the pallet jewel was loose to the point that it almost fell off. But the sellers were very nice. The seller of the non-working watch gave me a complete refund. Some of them gave partial refunds. I would say don't by luxury watches on the internet, regardless of the country the seller is from. Don't believe the "serviced by master watchmaker" statement. Have realistic expectations. ( Do expect the occasional complete junk.) Do expect to do a complete overhaul and major repairs. Otherwise, watches from Mumbai are great. For clocks.... I'm not so sure.
    • In 2020,I picked up an Orient Mako II online. It ran at +15 seconds per day and after 3 years of resets more than weekly, it was time to crack the seal and take a shot at regulating it. Not having a timegrapher, I used a spreadsheet to track the time, referenced the Canadian NRC website, wore the watch between adjustments, and used the back end of some tweezers to lightly tap the regulator daily until it ran to within one second per day.   Two months later, it’s still running to within 1 second per day when measured over a week or longer, while daily variations are up to 9 seconds per day. For my purposes, its overall stability is surprisingly good. Is this method of adjustment “better” than adjusting to 5 positions using a timegrapher, since during the adjustment period the watch is already in the environment in which it’ll be used? Rob in Winnipeg
    • Nice file  Just got old pocket watch in and tools,  can I get it back together or should I give up.  we'll see  thanks for the info
    • @HectorLooi Yes, I would say that Mumbai has the highest liquidity in terms used watches. How was your experience with these used watches and what watch brands did you buy used? I have always found the vintage luxury watch segment in India a bit shady. Quite a few are genuine watches with genuine matching parts but just not from the same one.
    • Interesting interpretation of "traditional". I would say that Loctite is definitely the up-to-date and appropriate stuff to use, however, it is a relatively modern solution. Before the advent of such esoteric solutions I believe that the "traditional" thread locker of choice may well have been a sugar solution. Once applied the water would evaporate and the sugar would crystalise, locking the threads tight.
