Watch Cleaner On Ebay - How Good Is It?
I am still making up my tools, and since I have been cleaning my watches by hand until now, I was looking on eBay for a watchcleaning machine that would make it easier and faster for me to accomplish the job. I came across this:
My question is: is it any good? It is said to be fully working, but I have no idea if all pieces are there. Any comment from you experts would be very much wellcome.
Yes Mark, there is no basket, but the seller says it would be easy to find one - I have no idea if this is true or not. Your experience?
I have no experience with sourcing a basket for a vintage cleaning machine George. But if the Elma SuperElite basket fits then those are very available.
Thanks, I will have a look at those, then. I did find another cleaning machine that looks to be complete, and at a cheaper price... Tough decisions,,, :)
If you can find an Elma superelite or similar then parts are quite easy to obtain. I managed to pick mine up for just £40 and just needed to replace the jar lids and corks. Good luck George :)
  • Similar Content
    • So leave off the seconds. Stand the movement on its edge, its the dial edge that rests on the pad ( either rubber or cork , something that wont slip ). Use a finger of your left hand to hold the movement upright,  right hand presses the release and flicks out the stem. I do it this way so i can see what I'm under a microscope. But you could hold the movement between two fingers of your left hand, its the right that has to manipulate the stem out by pushing the release and flicking out the stem with  right ring finger nail. Sounds more complicated than it actually is. I guess you could fix a push pin to something solid, then all you need to do is push the release against the pin, leaving your right hand completely free to pull the stem out.
    • A don't think so it leaked or damaged it because the watch itself works it just the buttons ain't working not connecting with the circuit board have taken more pictures of where the buttons makes contact with the circuit board.
    • I think what peter means oh is once he has fitted the hands and  checked for  alignment if them and that they dont foul, how does he then hold the movement to remove the stem in order to case up. The dial cannot be laid on a cushion or in a movement holder as the hands will get damaged. This can be quite tricky for a beginner, what i do is  to stand the movement on edge on a rubber pad so it doesn't slip. Hold the top edge with one finger then my dominant hand uses 3 fingers to press the stem release and flick out the stem. See below peter, leave off the second hand as this is the longest and gets caught the most, then fit it once the stem is out. Alternatively place the movement in one of the cup style holders, i imagine this is what they are designed for. They only touch the very edge of the dial.
