Older Pallet Forks and Shellac
Just a random thought, I just cleaned a movement and inspecting before reassembly. Pallet forks seem to be "shellaced" on one side. Does the Shellac ever age and need reapplied, seem that opposite side could have new applied and insure feet don't come loose over time.
The pallet fork looks fine, no issues with chemical or current setting. Just curious.
There are a lot of topic regarding IPA other harsh chemicals that dissolve shellac, I learned the hard way and switched to L&R fluids. Topics talked about different evaluations of how quickly shellac was being dissolved, but not on age and insuring movement's longevity. Especially concerning with the vintage movements I've been working with...parts are a bit hit or miss, obviously.
(Ultrasonic with L&R 111 for 10 min, #3 rinse for 5, second #3 rinse for 5.)
Pallet stones are normally only shellaced on the under side with no issues, there's no need to add more mass to the fork by adding more shellac.
This regime shouldn't cause you any issues. There is some debate about u/s baths and shellac although I've never had any issues and a lot of pro-cleaning machines use a u/s stage. There is also some concern about excessive first bath durations as some cleaners can have a less than sympathetic effect on plating. Unless you're dealing with something really stubborn you should be fine with just 5 mins in the L&R111.
I have worked with 150 year old Shellac on impulse jewels and palat forks with no issue at all.
I just reshellaced a pallet fork last night. The watch is a Titoni titoflex which I bought from an eBay seller from India. The watch was running but the positional error was unacceptable.
I found that the shellac was missing on one side and the other side was cracked.
When the OP said "shellaced" on one side, does he mean this?
Typically with pallet forks the shellac is usually fine even with vintage pocket watches. But you do always need to check just in case.
In the case of the roller jewel or impulse jewel in a pocket watch you always check to make sure they're not loose. There isn't any reason why the shellac should break down but more than likely if its vintage somebody's change the balance staff is always worth checking to make sure the roller jewel is in tight.
    • I will try this weekend.  I've tried several times with my cell phone and it's just too small and recessed to get a good picture.  I need to get my macro lens and tripod out and then figure out how to get enough light down the hole in the side of the man plate to  actually show the top of the broken screw. I appreciate the effort and will try and get that pic this weekend.
    • Hi,   My name is Simeon I am based in Sydney, Australia and have recently got into watch repair / watch making.  I am very much a learner having serviced multiple forgotten watches, some of which were actually successful!   I have a slowly growing collection of watches, mainly old Soviet, a few Japanese and (not pictured) some Raketas, a Poljot Alarm, an Omega Speedmaster Reduced and a vintage (1972) Tissot Seastar.  I like unloved vintage watches, with quirky faces and enjoy bringing them back to life through the simple(!) act of disassembly, clearing and reassembly. I am an Electrical Engineer who also undertook a trade apprenticeship so I am reasonably handy - It's fair to say, I know just enough to get myself in trouble.
    • ha ha looks like a WMD.....you know I want one now
    • I took a chance on a non running Cosmotron X8 ("perhaps just needs a new battery" said the advert). Sure enough, I open it up and it has the wrong battery installed (a Renata 344 rather than the correct Renata 386) and the screws holding the battery contact had been sheared off to half a head on both ends. Ho ho, I thought - there's the problem. I got the broken screws out easily enough and as soon as I placed the correct battery in place the balance started. This picked up speed when I reinstalled one side of the battery contact and looked like it was a runner. As I was trying to get the replacement screws in, I did one side but the second was a bit of struggle (hold down the battery contact against its spring while dropping the screw in with tweezers) the balance stopped again. This time it wouldn't start again. 98 percent sure that I didn't stick anything, anywhere important or break it in a mechanical way. The battery was in place for most of the struggling with the contact, so it might have had an intermittent connection which could have upset the electronics. I tried giving it a puff with the blower but the balance doesn't seem to rotate in the normal way, it seems to be held in a static position by magnet. It can be pulled out of this position but spins back and stops dead. This may well be correct for all I know. Anyway, does anyone know anything about these watches and can tell me how I would go about and fault find this? I will be servicing it at some point so should be able to rule out mechanical issues from an old watch but not sure where to start with the electrical part of it.
