Pallet warmers
HectorLooi
Over the years, I've collected 3 different pallet warmers. I've figured out how to use the 2 seen on the right, but the 1 on the left remains a mystery.
The long skinny end has scorch marks, so that's the end that is heated. But where is the pallet fork supposed to be placed?
TIA
Hi there HectorLooi, the one on the left is for roller table jewel replacement. Watch this video it shows how to use.
Hope this helps.
Graziano
Thanks Graziano. So that's what it's for.
Melting shellac on a pallet warmer is almost like watching paint dry. I've always wondered if it's possible to use my hot air soldering station at the lowest temperature and air velocity to do the job. Has anyone tried that?
Technically that's not the correct answer? Yes that's typically what I think that tool is for typically it's what everyone uses it for until they realize that it has another use like it will work with pallet forks and even as other uses possibly?
What I was thinking about for the roller/universal tool would be to make an electric heater for it. Below is really a pain to do a roller to hold onto the tool play with the shellac play with the jewel and worry about the flame. Electric heater would be so much nicer. So it's on my list of projects to do that aren't getting done very fast at all.
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
    • Yea a have given it a full service this movement is chinese 2813 whats the lift angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?   Hi you said my lift angle is default how do a remove this from my timegrapher?
