Watchmaking kit
https://www.uncommongoods.com/product/diy-watchmaking-kit-medium-difficulty
I was scrolling through this site over lunch halfway looking for a desk fidget toy for my toddler so she doesn't try to grab things she shouldn't when we're "working". I stumbled on this. Miyota 8215, sapphire crystal, stainless case (if you get the silver one)... Pretty decent. One thing caught my eye though that gave me some serious pause/raised questions that are not answered. See if you can spot it.
Continued scrolling and found this one:
https://www.uncommongoods.com/product/diy-watchmaking-kit-hard-difficulty
Actual ETA movement. "Hard difficulty" seems to mean a small seconds hand, and it looks like maybe they removed the ratchet wheel and click? Still, same pause/questions as the "medium difficulty" version.
Exactly what I wanted to know!
It also took me a second on those giant pliers, but I think they're most likely for cutting the stem. After a few hours of it rattling around in the back of my head, I'm thinking the superglue MIGHT be to glue the crown on the stem...? Best guess. Next best guess is that they only have a single size screwdriver in the kit, and dial retention screws tend to be itty bitty... Might be the glue is to hold the dial on? That would be awful, but that was my knee jerk reaction owing to a recent experience. Hands and spring bars loose in that little plastic container seems a bit iffy as well, but maybe that's not actually how they're shipped...?
The "Hard difficulty" version is cheaper than the "Medium difficulty" version, and comes with a 17 jewel ETA instead of a 21 jewel Miyota. I would have expected the ETA to be more expensive, but admittedly it's too difficult for me to buy ETA parts anyway, so I don't keep a thumb on that pulse. I don't think I ever came across an "Easy difficulty" version. I'm not completely sure what it is about the "Hard" version that's more challenging than the "Medium" one. The small second hand pivot can be pretty fragile maybe. Surely the ratchet wheel/click being removed isn't what they're intimating is more difficult though. I'm not sure what other differences there are between the two kits from an assembly perspective. Installing that would be much easier than... installing hands? I don't know. None of the activities involved in assembling either kit register as part of a service; just stuff you do when you're all done to sort of clean up before moving onto the next thing...
    • Post some pictures , some good close ones of the parts you've described.
    • Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. If its a potential problem for amateurs to use then i would prefer not to take the risk .
    • Following on from my question about identifying screws in the AS2063 movement that basically fell out of the case in bits, I’m pleased to report that I’ve got it all back together, and the movement is running pretty well.    But… There’s something wrong with the keyless works and hand setting. It’s fine in winding and quickset date position - these work - but in hand setting position winding the crown turns the whole gear train.  I don’t really understand how it’s meant to work. It doesn’t have a traditional friction fit cannon pinion.  The second wheel is unusual with a pair of smaller pinions on it, which seem to interact with the barrel and the motion works.    Could this be the problem? I must admit I just cleaned it and popped it in place when reassembling the gear train. I’ve lubricated the pivots but didn’t do anything to the extra bits on the second wheel.    Does this make sense and is anyone able to figure out what I’m doing wrong? Thanks in advance, as always.    ETA - the parts list calls it the Great Wheel, not second wheel.
    • You're thinking metal to jewel in general I guess. Maybe it would be a good idea to peg the pallet staff jewel hole on the main plate after the epilame treatment. I think that could work as it is my impression that the epilame doesn't sit very hard, but I could be wrong about that so feel free to educate me. I didn't remember that 9501 was thixotropic (thanks for the link). That would mean it's even runnier during impact (lower viscosity) so perhaps it's time I get some fresh grease as mine seems a bit too runny. What I have seen is a whitish surface after washing but it goes away if I scrub the surface with a brush in a degreaser (Horosolv). I don't think it embeds itself in the metal but sticks very hard to the metal. I don't worry too much about the cleaning solution. I just want perfectly clean parts and my solution can be replaced for little money (ELMA RED 1:9). Anyway, I quite often need "to strip back and rebuild" and scrubbing parts by hand isn't exactly the most stimulating part of a service. Just got confirmation that Moebius 9501 has a lower viscosity (68 cSt at 20° C) than 9504 (305 cSt at 20°). The viscosity of Molykote DX is 285-315 cSt at -25° to +125° C. I was surprised to see that the viscosity of Moebius 9010 (thin oil!) is higher (150 cSt at 20°) than my 9501 grease!
    • I’ve had a couple movements where it is clear the previous watchmaker was diligent with lubrication but the old epilam had turned to a fine white powder covering the pallet fork and keyless parts, which can’t be good for parts. I’m spare with epi since I don’t know how long it takes to degrade to that state…
