Ordered two of the movements needed for the course today !
One to use and a spare one for the occasional hamfisted moments !
Found a vendor in Germany who is selling them for a few Euro more then the Chinese outlets.
For Europeans, that avoids 'trouble' with Customs and much shorter delivery times
Paddy
Hey Paddy, welcome aboard and good luck with the first stripdown and reassembly.
Just for your reference, you may want to search through this forum for threads relating to Seagull incabloc shock spring replacement. FYI, they are not hinged like the high-class ETA movement, and will want to fall out the back of the setting. Just to save you the inevitable horror.
John
I had one spring leave from the back of an Incabloc also. All ended well, but placing it back was quite an annoyance.
John,
I have done plenty of stripdowns and reassemblies, but not on this type of Chinese movement...so we'll see what nasty surprises it has in store.
Sound like you are saying that the springs proper are missing the hinge parts.... would it be possible to replace them with ETA equivalents that have the hinge part? Or would those just not fit?
Paddy
Would not fit, Chinese watches have parts that may be similar to the original, but then different enough to prevent complete interchangeability.
Movements arrived today...well packaged,
Included were a dial washer some case clamps and what seems to be an extra wheel....
They seem to work, so that is progress after a fashion!
Wonder what the extra wheel is about though....
Paddy
I will, as soon as I can find something to take pictures with ....
(please do note , I am the worse photographer in the EU and surrounding small villages !) My phone has a camera, but I'd need to put in a micro SD card, in order to be able to take a picture...one of my sons will be around one of these days, and they all have these snazzy new phones, with cameras that surpass anything you could buy have even a few years ago...)
Paddy
Edited by Paddy1302
forgot stuff
Paddy
The extra wheel is likely to be the hour wheel, which is normally not fitted on movements sold by themselves; they are supplied together with the movement in a small bag. This is because the hour wheel is kept in place by the dial, and without the dial, is likely to fall off.
Seems to be that way yes.... neatly packaged though
Didn't really know what to expect , I guess
Gave it a wind and it keeps on "keeping on", but I haven't put it on the timegrapher yet.
Might do that over the weekend ..
Thanks for your reply !!
Paddy
    • Hi All, I’m having a hard time finding a balance assembly or even a working donor movement for a Gruen 330.  Any leads appreciated.   Gruen doesn’t stamp the caliber number of the movement but lust in the case back.
    • Why do you think this is Fontainemelon ?  The balance staff you will need to source separately.  But first it's important to accurately identify what you have there. Research Ebauches Sa, see who was in group, to find the brand that made this movement.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
