Anyone recognise this brand?
Michael1962
The pallets just need smoothing off with a very fine emery stick. The escape wheel has had it, I don't think I have seen one that bad where nearly all the teeth have been striped off. Having a new one cut will be expensive, not having any positive I D of the movement will make it hard to get a replacement.
Hi Michael I have never seen an escape wheel like it, worn or otherwise to that extent. The movement to all intents and purposes looks like a Chinese/ Korean copy of a Hermle 1051-850 with a few subtle alterations.  I take it’s a weight driven clock, with two weights and is a Westminster chime.  Parts are going to be a problem as Old Hippy said, strangely the pallets show very little wear which leads to a quality issue with the brass used in the escape wheel. Checkout all the pivot bearings for wear.  Cheers
When I put the pallet arbor back in to check the movement of the escape wheel against the pallets, if the teeth on the escape wheel were greatly longer, as per other escape wheels, the pallets would not move through a large enough arc to clear a tooth to allow the wheel to progress.
It almost looks like the escape wheel, on top of appearing to be greatly worn down, has those rectangular recesses in the wheel circumference in between what I suppose you would call the tooth chord. The pallets can't have worn that so it must be there from manufacture.
3 weights @watchweasol
Maybe it was just rubbish brass. I am astonished though that the pallets show very little to suggest what has happened to the escape wheel.
Looking at the escape wheel , I think it may have been a recoil wheel. What is left of the the teeth, seem to slope away from the entry pallet and not toward it.
The pallets are not dead beat there for it is an anchor escapement which will have recoil, the recoil happens after the tooth has escaped and the escape wheel moves slightly backwards, this is very easy to see when a clock has a seconds hand. With a dead beat you do not have recoil of any sort, also the teeth on the escape wheel are different.
What I think has happened here with the escape wheel is it had a lot of power on and someone tried to adjust the dept by undoing the screws to the pallet cock and raising it this caused tripping and ripped the teeth down to what we now see, the reason the pallets don't show any bad damage is steel is harder then brass.
    • Thanks Rich, its really not that difficult to make them, simple ones anyway. Cousins didn't have the part though i could find it on ebay at 6.50. I figure i earned about £1.50/ hr . It paid for the diamond files i bought.
    • If you look at this thread, you can see I had exactly the same problems with balance springs with 2 prongs on a Smiths 627. The slots in the chaton were not big enough to get the ends of the spring out. I had to bend them to get them out and back in. Not ideal. I don't fancy having to do it again as they could easily break, and where would you find replacements? I didn't come across the 3 prong type.
    • I visited the Breguet Exhibition today. https://www.sciencemuseum.org.uk/about-us/press-office/rare-timepieces-unveiled-new-display-science-museum The Science Museum now holds the collection of "The Worshipful Company of Clockmakers" - "The collection includes more than 600 watches, 90 clocks, 30 marine chronometers and a number of fine sundials and examples of hand engraving, mapping the history of innovation in watch and clock making in London from 1600 to the present day." It's well worth a visit. They have some amazing pieces by the likes of Harrison, Breguet, Tompion etc . I've visited twice before but decided to go and see the Breguet Exhibition. Maybe I was expecting too much, as on reflection, "More than 20 extraordinary timepieces designed by inventor and watchmaker Abraham-Louis Breguet " isn't going to take up that much space. In reality, it's just one cabinet. But, Oh those watches, stunning 🤩 , e.g. (No 1297 was made for George III and is valued about £1m)   I tried a couple of pics, but with subdued lighting and taking through glass, they aren't good. I like thin hands on a watch - how about these (I think this is a split second chrono)   And this one, with all it's complications, is only 10mm thick !   What I found very interesting were a few very old machines for making watch parts, like this 17th Century gear cutter. The disc below has concentric rings with holes in, so that is can be set to cut varying teeth numbers.
    • Firstly sorry for poor image quality I only have an iPhone for photos.    Im working on a 512 movement and I’ve had some trouble with the “jewels”. I’ve got the metal one out, but when I tried to put it back the three sides of the spring seem to need pressing all at once to fit it as there are three “holes”. I get two corners in but as I go for the third the first two pop out! Constantly I’ve lost the spring. I’ve done the similar ones on seiko movements without trouble. Assuming I find it/a replacement, what am I missing!   on the other side with the only ruby in the movement is a setting with no “gap”at all. How do I get the spring out, and of course get it back in!    What am I missing!    thanks in advance.    Rob
    • Links like that are the reason I routinely donate to the Internet Archive - they are the last safe house for a tremendous amount of useful info that is otherwise lost.
