Hi folks,
Sometimes I come across watches with bent curb pins. For example, often the pins are pushed together on old pocket watches, or pins are bent out of shape for one reason or another. Can people share best practices for adjusting them? Are there any specialized tools for this? Many thanks.
HI JohnC, on a pocket watch with 2 pins, remove the balance cock but with the hairpin stud intact. Turn the balance wheel together with the cock over; hold the cock & the balance up & use a thin sharp pointed blade [ similar to a scalpel ] to slightly open the pins enough to clear the hairspring thickness. The reason for the pins set towards one another is to prevent the hairspring from being dislodged. If a watch has two regulating pins they should be parallel, not bent towards each other. Generally the spacing between them is about 1.5 to 2 times the thickness of the hairspring. The spring is not "captured" but should be centered between the pins with no power to the watch. At normal amplitude the spring will bounce from one pin to the other. This is true also with the single pin and guard, the spring should be bouncing between the two when amplitude is "normal"
On wrist watches what I do is if the single pin is bent I use flat tweezers and ever so gently straighten the pin but I don't move in any direction. Chances are it will snap. Once the pin is straight as in no bends in it, I then proceed to nudge it in the direction needed, from about the middle of the pin. You really only have one shot at this on a wristwatch as the pin snaps at the base very easily. Anyway that's what I do. I haven't seen any tools specifically for the job but I use hairspring manipulating tools to push the pin.
Hope this helps
Graziano
You want the pins straight, and parallel, with a gap approximately equal to two spring thicknesses. The gap is a guide, you might want it closer, for example an overcoil would like a very small gap (just free) as OH said. Depending on how the pins are installed and their spacing. One some older pieces they are spaced a bit, so you have to bend them toward each other, then straighten. I just use fine tweezers for this, like #5. Sometimes to widen the gap a little those are still too big, then I will use a broken oiler that has been stoned to a very fine wedge shape (like a microscopic screwdriver). That will fit in the smallest gap and allow some tweaking.
Thanks guys. I guess my concern with moving brass pins outward is using a steel implement on the inside, where the hairspring will bounce. I try not to touch the bottom inside of the curb pin, where the hairspring will make contact, as I don't want to bruise the pin and cause the hairspring to not bounce off cleanly. Anyway, all your suggestions are helpful. I will try the sharpened oiler trick.
    • Regarding the spring winders, I made my own and used copper pipe reducers as the tubes to retain the spring. You will need to cut out a section for the end of the spring to protrude but if you watch one of the many videos on this subject that will make sense. You can find a selection of sizes on Ebay for very little cost. I'll attach a pic showing one of mine.  Good luck!
    • There were things bothering me about this discussion that took me a while to figure out the problem. In the image below it appears to be the spring may be pushing up? Normally when Omega has a spring pushing up the pinion has a pivot with a bridge to hold it in place so in other words the spring can push on something that stationary as opposed to this which appears to be floating? To understand the problem with the above image we need another image of side view which I have below. In my image down below on the left-hand side it agrees with the image up above. But the only problem is the left-hand side is defective and the right-hand side image is the way it's supposed to look. Then Omega if you can access the right documents does explain how and why this problem occurs. With the pinion floating around it might be assumed that you support it when putting on all the hands but you do not because as noted below if you do this small bush on the pinion will relocate out of position exactly what we see in the image up above.   Then Omega does not mention this but there is a possibility of also damaging the pinion and causing the bush to move to where it's not supposed to be when removing the hands.
    • Maybe show us 1) the watch, 2) timegrapher readings in DU, DD, PU, and PD.
    • The timegrapher displays significant beat error variations in the dial-up position. When the watch is lying flat (face up), the beat error is much higher than in other positions. Beat error readings are inconsistent, with especially large gaps in the face-up position.  Please help !
    • Looks like an open-access journal that runs as a glorified pre-print server with no true peer review, so it’s not easy to judge the veracity of the conclusions.
