Oil dispenser.
Plato
I might be the only one whose ever had a problem with this but I thought I should share, just in case.
I could never find a suitable way to get oil from those little Moebius bottles without wasting as much oil as I transferred to the oil cup.
I searched online for 'small/mini/micro spoons' but came up short. I then stumbled onto an object called an ear pick or scoop which seemed perfect. I bought a set (6 items) on Amazon for £6 and they fit perfectly. Please let me know if there's a better way.
1 hour ago, KarlvonKoln said:
I wonder if an old glass eye-dropper would work for this too.  I think I may still have one in the house someplace.
I have tried that too but they're really hard to clean, I don't want to risk mixing the oils. Unless the eye-droppers can be capped and kept with each oil jar?
Good point.  I'd need different ones with caps.  Or maybe inexpensive pipettes?  And find a way to plug or cap those?
I use disposable plastic pipettes. You can get a batch of 50 or 100 for dirt cheap off Amazon or eBay. It's easy to control small amounts, especially with the 1-2 mL sizes.
Just to be on the safe side, I suck up a small amount and expel it in waste, and do this a couple of times, to remove any traces of plasticizer or other garbage on the inside walls from manufacture before dispensing an aliquot into the oil cup.
I found this works the best, and the Moebius 2 mL vials have a pretty wide opening.
I use a piece of fine wire with a loop at the end. Dip loop in oil and transfer to oil cup, repeat until desired amount. This avoids oil being wasted on the rest of the wire.  I always clean before and after use and keep wire for each oil grade in small plastic envelope so it is exclusive to each oil.
    • So that is what the last person to work on this movement appears to have done.  There was a "wad" of adhesive material in the vicinity of that hole when I took the dial off.  I was hoping to take the high road and fix the issue in the work I did on this movement. I wasn't sure if I was imagining things or not when I looked at the screw hole, but it does appear to be somewhat distended.  I had not considered the posibility that someone had forced a screw that too big in there.  I had wondered about using a technique I've applied in other applications (where the screws are in the same scale as human hands) that involves counter drilling the plug with a  reverse threaded tap.  When I've had to do that in the past, the screw has generally caught and backed out from the torque on the tap (instead of yielding and letting the tap bore into it.)  I don't like doing that, but it's saved my rear a couple of times, but the smallest bolt I've tried that on had a 5 mm head.  This is an entirely different ball of wax. I am still contemplating disolving the screw with alum, even if that means I have to stick the dial down with double sided tape until I gain the skills to actually replace the screw.
    • Hi Thomas, you should be able to find the right (or on close to beeing) in a Ronda or DCN balance staff catalogue. Cousins uk have those available as a download.
    • Hello everyone. My name is Cees (pronounced "case"). I have been working on watches for a few years now. Got down the rabbit hole when I started watching "how to" videos on watch repair when my watch broke while on holiday. I'm not interested in collecting watches, but purely in the technical side. I love fixing them and also love collecting the tools I need (or might possibly need one day...).
    • The movement is FHF, something like this. But it will not help much to find stem.  Sometimes making one is easier
    • I think they all have their pros and cons, the one I suggested is a threadlock loctite product (Loctite is now owned by Henkel), In general I use the current one that is recommended on their Loctite page (link here)   I use blue (243) for the actual crown the (stick is actually 248 which is the stick version of 243), like I said it is very convenient for using on stems. Blue holds the crown for everyday use, but can be removed if you need to with a little heat. I use the red 277 for things like stem extensions where I have no intention of ever removing it. The purple I don't use (but I have seen some youtubers use it) as I think the blue is removable so why take the risk on a weaker product.   This is interesting, and a useful bit of information to know 🙂
