Gearing Up My Tools Set
Affnan
Its looks like I'll be serious in doing watches.. firstly I work with tools all my life in the Aviation industry doing Avionics or B2 in the European area and we use high quality tools no compromise there. On the personal ground I do love doing Cars and Bikes and as I said before, age is cropping up and I am not in the prime as I once was. Watch making looks like a good alternative when I retired.. in few years.
So here I am doing watches... and from the few reply I got on my intro post.. many here are somehow in the same boat..
Only started to have interest on watches late last year and buying tools to do the simple job, since I am learning. The tools I have are mostly Chinese made.. and it does say "High Quality" .. well it doesn't cut it, especially the smaller end of the scale where they fail.. either sending screws flying or distorted tip of the screw drivers.
Decided to take the plunge and take a deep breathe and go for better quality tools... what I had in mind was A*F, Horotec and Bergeon .. Bergeon being last in the list due to the price scares me.. Visited a watch shop in Kuala Lumpur to check what tools they have and it look like I have to reach deeper since they do mostly Bergeon.. !!! :(
My first high quality tool to show and replacing the ones that I use ...
Bergeon Screwdriver Set No. 30081-S09
Replacing my "High Quality" Chinese set... :) on the right.
Being 53, its obvious my eye sight is no more 20-20 so I have to take care of what is left. I need a better loupe then I am using now.. those are the cheap dime a dozen on ebay.. so a Bergeon No 2611 No. 2 Loupe is added to the **BLEEP**nal.
As a start, these are the higher quality tools that I am getting to replace my current sets of tools. I do not want to over do it .. slowly but surely and like most people doing new stuff I am trying hard to avoid the "Gear Crazy" bug
Really interesting topic, i was aiming to change my cheap tools into a Bergeon tools.
So, where/how can i buy Bergeon tools with safety about the authenticity?
Check that screen
I'm a 99% sure, that isn't an original.
Do you follow any particular seller on Ebay?
@ Icarus,
Have you tried local suppliers near your place?...or even directly from UK or USA? We have a section here where you can find suppliers from all over, make sure you check them out for convenience!
@ Affnan,
Good move, Affnan, you will notice the difference and will enjoy your work more!
Cheers,
Bob
@ Icarus,
Yes, my father it's a watchmaker for almost 20 years and his dont care much about the tools quality as i, so we know all the sellers here in my region, they ALL sell only #$%@# stuffs from china.
I never bought Tools from Ebay, becose of this i asked, i'll try to search this section on fórum.
Thank you, Bob
To buy absolute genuine then I would avoid eBay use a recognised supplier. The oyster case opener for Rolex I purchased & it did not work it slipped under pressure. Purchased the Horotec case opener with the appropriate die & no problems.
@ Icarus,
@ Affnan,
Cheers,
Bob
Yes.. Bob.., it is so much easier as compared to my previous set... no slips and it is a very sure footer on the screw. It worth the hard earned cash that I paid for it.
@Icarus, those tool on ebay that you show tho the box is yellow, they will come with a Chinese names. I did purchase 1 or 2 of those as Clockboy said.. is very true, I experience the same. I had ordered one item from Cousinsuk and waiting for it, will see if it's ok I'll purchase more from them since I find their postage is very reasonable.
Affnan
    • I've managed to adjust it. I'm going to try and explain it as well as I can with my limited horology knowledge but I hope it helps someone in the future. There is a cam to the right of the front plate as shown in the picture. As the clock ticks along, the pin indicated in the gear comes around and slots into one of the silencer cam gaps, turning the cam. The pin completes a full rotation in 2 hours. To adjust the cam to start at the right time set the clock to just before 7. I did 6:45. Then I turned the silencer cam anticlockwise, which spins freely, until it pushed the silencer lever up and was placed just before the drop. Just before the 7AM indicated in the picture. All I then had to do was progress the hands to 7-7:15which made the pin slot into the silencer cam gap and turn the cam so the lever comes down again, unsilencing the clock. That was it. If anyone comes across this issue again I'd be happy to assist. Thanks again to everyone that helped.
    • Now I'm completely confused, it would appear that the epilame  is oleophobic  as @Marc states: This oleophobic  behavior can be seen as beading of the droplet (as above) which stops the oil spreading which is supported by what we observe on treated/untreated cap stones (for example), but as @VWatchie states this should make the drops more mobile, and not less mobile which is the opposite of what we want. In fact this beading and high mobility are desirable properties in things like smart phone covers, see below.  I am fairly sure that epilame doesn't make the droplets more mobile, so maybe its a strange coating with dual properties that are both oleophobic and cohesive/adhesive resulting in low mobility?? This may explain the high price??
    • The description there is exactly how it's done, and it's very well written!
    • Would it be correct to say that the stronger the mainspring, the thicker the oil should be? So for a fusee mainspring, should a thick grease be used?
    • I started on pocket watches as they are easier to work on than wristwatches. Many had gold cases, which is why there are so many movements for sale. I was always on the look out for cases, for as Nickelsilver says,  a 16s movement will fit any 16s case* (with tweaks to the stem). I also started hand winding mainsprings, before I had winders. It can be done without damage, but it's quite hard on the fingers.  But you can make homemade winders, see here      * some movements, eg "railroad grade", have a setting lever on the edge of the  dial at about the 1 -2 o'clock, so need a special case.
