FHF / ST history
Hi all!
The mother of my fiance asked me to repair a little old watch belonged to her sister since around 1965.
It is a little 20mm Mondaine, with a manual winding movement.
The movement has a mark on the dial side "ST 69". It is a 17 jewels swiss made movement. I did some research and I found a very similar movement from FHF, called 69N.
Both movements are practically identical but for the balance end stones: ST69 does not have the incabloc system on the balance.
Do anyone know if the movement I have is from FHF but their did not marking it? Or does the "ST" stand for another company? Were them the same company?
I leave you some images 🙂
Edited by ElioBD13
Add a photo
ST = Standard, the name suggest generic in nature, could have been a separate logo andcompany but in the end made identical mov.ts as FHF, AS, and others but never an unique one. Maybe they were owned by the same people, or sold, or acquired, or produced on contract. That happened all the time in the Swiss industry and still does, for fiscal and market reason.
2 hours ago, ElioBD13 said:
So I can suppose that, even if the balance doesn't have the incabloc system, parts from a FHF 69N will fit.
Other parts yes, but due to the different pivot profiles one can't mix plain and anti-shock balance parts.
What was, and is still used, to greatly resume parts commonality is the Bestfit catalogue. Search for it on this website, courtesy of oldhippie.
What was, and is still used, to quickly resume parts commonality is the Bestfit catalogue. Search for it on this website, courtesy of oldhippie.
2 hours ago, Nucejoe said:
They are two seperate brands but made many exact same calibers marked ST or FHF or ST-FHF.
Find answers to many of your questions in Dr ranfft and Julesborel sites.
I'll definitely check for their sites!
Very good advice, I didn't know that.
I will! Thanks JDM, and thanks @oldhippy 😉
 Both ST &  FHF came with no shock and incab as well as other shock systems.
Dr ranfft shows a FHF69 with elstor spring I beleve.
Just go to ranfft's site to see FHF69, thats a pretty darn good spring on fhf69.
ST mainly made elabore grade ( I think) with incab, which powered many brands.
You would be concerned with shock system when replacing the balance complete or the jewel setting. The one in the watch is very likely to be the right one for it.Only end stones in your watch differ.
  • 2 years later...
Hello there,
I have just run into the exact same issue about "incompatible" shocks across FHF 69N.
I have a watch in repair with this caliber, it is my mom's watch, a very young one. I mean the watch. 🙂
It's in a Doxa from the 90s. (I was very much surprised that I have found this caliber in a Doxa, I thought there should be a doxa caliber inside. Maybe its a cheapo doxa. 🙂 )
So in this watch the shock springs are not incabloc, but some other type, it's called Novodiac if I'm not mistaken.
When I lost the bottom end stone and pivot hole 🙂, (Am I right if I call the dial side "bottom"? Actually it should be top, as it is in the top almost any time, except when serviced and opened upside down. 🙂) I just ordered a replacement movement, was thinking I just need to replace them, easy work.
Then I was surprised, that the replacement movement had the incabloc-type shock springs and different size of jewels.
So I realized that no matter if it is the same movement, the balance shock jewels and springs are different.
I tried to use the replacement balance assembly with its jewels, but on the dial side, the seating is different, so the pivot hole and the endstone height is also different, and the balance does not oscillate. I think the end stone pushes the pivot when the spring is attached.
So the problem is, no matter how many "for parts or repair" movement I see online, all of them looks like fitted with the inca system, and not novodiac.
And also, unfortunately the sizes close to what I have measured on the novodiac jewels are not available on cousins or boley.
So for now - unless any of you had a brilliant idea that I as a beginner cannot think of - it looks like I have just ruined my mom's watch that was working perfectly, just needed a service after like 30 years.
But hey, lesson learnt! Since then I have the special tool for novodiac springs, 4 more spare springs for this watch and 2 movements, so once I could buy stones for this novodiac shock, this watch will have all the spare parts for the next 100 years... 🙂
This is the Novodiac shock, fitted with incorrect jewels.
 So many brands were powered by ST69 manufacturers simply ordered the shock system of their choice.
I think your watch is genuine ,  more pix please just to make sure.
Removing shock spring in a plastic bag, keeps the spring on earth.
A strong magnet has  a good chance of finding the spring.
Rgds
Edited by Nucejoe
    • Looks like it’s be perfect for my anvil problem, but I’d be concerned about using on a watch movement re: I’d be afraid to apply that much magnetic force to a hairspring.
    • Hi a have bunch pallets jewel here a want to replace it with a broken one how do a know witch is the entry stone or exit I know normally the exit one has a bigger locking corners ?
    • I use on of these Eclipse demagnetisers. https://www.eclipsemagnetics.com/products/workholding-systems/table-top-demagnetiser/ I got fed up with those Mickey Mouse blue things and went industrial You can pick them up on eBay from between £70 to £100. They will demagnetise anything. I mean, anything, from a hairspring to a hammer head. The table is about 5 x 6 inches. You are not going to find anything close to being this good! It will demagnetise the biggest and chunkiest of cases with the movement inside. You'll never wonder again if your demagnetiser did the job.
    • Hi Dean, The solution with the alum for the broken screw is good and is generally used by watchmakers from many years, but You have to take off ALL steel parts from the plate. In some movements, the post for the minute wheel, for example, is made of steel. Deeping partly the plate works too, but some marks may left on the line where the solution doesn't cover the plate. Heating the solution is needed to accelerate the process. With the years, a rich collection of screws gathers and then finding the needed screw is not a problem. But till then it will be helpfull if You get some assorted screws lot. The other option is making screws. This is usually for the ones with specific form and sizes that doesn't meet often. But the skill of making screws is something that will never be unnecessary
    • Haha yes you do have to reel in your bidding enthusiasm Michael. I use a " not enough time policy " to restrict myself or else known as sniper bidding. Decide what you are most prepared to bid and place it 7 seconds before the end, cross your fingers ,job done . The price paid here i would say was top  figure another day could have been $40
