Dear Watchmakers
I purchased an IWC Ref. 1871. It seems to be a true project I am looking forward to work on.
But the first and probably major problem for me is to open the case. It is a square case body that has cut outs in the corners of the back. Each corner has a tiny bore, too.
I did my homework and searched for information online and found a discussion on the Omega forum about the same topic with some hints but with no real result for me. Hints: the case is the same as the one on the “Zenith Respirator”, it works with spring-loaded pins, URL:
https://omegaforums.net/threads/iwc-case-problem-how-to-open-help-needed.16751/
On a website of a dealer I found an image of an opened Zenith case. I can see bolts on the sides of the inner part of the case that contains the movement, URL:
https://www.vtgwatch.com/zenith-respirator-luxe-automatic-28800-date-vintage-watch-vtgwatch.html
Does anyone have some experience?
Best
Thanks, I have found that website as well, but the writer does not explain, how he opened the case.
He did not answer the same question that was also asked by a website visitor in 2018 (see comments below the service walk through presentation).
This is where it is levered I would say. Gently try it with a couple of screwdrivers either end. These recessed parts of the case have been put there for a reason. However be careful because if the dial is tight or has a overhang it will be easy to damage.
I managed to open the case with tips from IWC specialists.
In short:
You have to push on the crystal to separate the case back containing the movement from the upper case.
In detail:
You do not need to push the pins back with screwdrivers. There is not enough space anyway, you need a lot of force and you end up damaging the case and the screwdriver. Furthermore, you will somehow push the case together instead of apart.
Expecting that everything will stick together since the last service is ages ago, I put a tiny amount of WD40 into the holes of the spring-loaded pins (see photo above), the space between the case parts and the slot between the crystal and the upper case. I let it soak for some time. Do not use too much WD40… this is watch making here.
Place the watch on its lugs on support blocks (e.g. wood blocks) to generate clearance for the case back to come out.
With your thumbs push gently on one side of the crystal at six or twelve o’clock roughly where the pins are located. Push on the stiffer crystal edge and not on the centre to avoid crystal damage. I could not find a potential replacement for the crystal so far.
The pins are chamfered and will be pushed back automatically from the force applied until the case back is separated from the other case part.
The watch has a split stem. To remove the movement from the case back, first remove the split stem with the crown.
I guess this workflow is the same for the case of the Zenith Respirator.
Happy watch opening!
That's awesome, thanks for the update and detailed description! I work on lots of vintage high end Swiss stuff and haven't run across this case. Big fan of IWC too.
I once had a Seiko with those pins in the case. I’m not surprised that design was phased out as it’s a bit of a faff.
Small correction to my technical drawing of section cut above:
The rubber gasket goes around the dial and is not placed between the crystal and dial as in my sketch. The previous watchmaker did a bad job by squeezing the gasket between the crystal and dial. This left black stains on it…
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
    • Seems to still do it through my mobile data, I use an android phone almost exclusively, but I'll double check it. Thanks mark Strange, I'll try my laptop that utilities edge. I've been on site half hour since I got home, it hasn't done it yet. Thanks John
    • At work, I'm on MS Edge, not through chose, on my phone, chrome, no issues with either.
