Bergeon 2462 graver sharpener
Thanks for all the help. Starting to learn how all the parts are called in the meantime from the linked file. Taking me a while - old dogs, new tricks. Supposed to be good for keeping the brain active though! If there's deep scratches on the casing, is there any merit in taking it down to brass? I read nickel-plating brass is relatively easy and can be done with just a nickel anode and salt+vinegar solution - no need for crazy acids. Has anyone done it on a watch case with any success?
By LittleWatchShop · Posted
When I saw this, I knew I had seen these tools in my collection. Recently acquired estate for pennies. -
Thank you @AndyGSi for valuable insight. It helps a lot.
It's a tapered pin like these.
I'm working on an old pocket watch, and I lost the small bolt that is pushed into the hole of the stud to attach the hair spring. Has this part a specific name, and can this be sourced generically? Are there assortments of these parts, or do I need to look for the exact piece? Thanks Stephan
