Birmingham watch fair
I think this is one of the two DVDs that I bought. I can't find them at the moment. I think the other one was "WORKSHOP PROCEDURES." Both were very worth watching. I remember a section on making lantern pinions that was excellent, and also a demonstration of cutting an internal ring gear. Not sure if that was on this disc or the other one. I expect you would find the DVD interesting if you have time to watch it.
By rjenkinsgb · Posted
It depends on the exact movement and jewel in that. If such a size is available to buy. Not impossible, but likely a small percentage of types overall. Most of the time it's more economical to buy a replacement plate or bridge from ebay; the tooling needed to replace jewels is expensive and probably rarely used, unless you are running a dedicated watch repair business. -
Yes every single watch in the universe can be repaired. But he was asking a question about getting a parts movement. So now you get the task of showing him how to repair the watch without getting a parts movement I'm sure it shouldn't be a problem at all for someone of your skill set
