Fixing Old Coin Silver S18 Case
Working on an 1885 Illinois Pocket Watch and it’s case back does not close properly. I think it was pulled back beyond spec at some time in its 150 years. Does anyone have any advice on how to get the lid back into place. Here are the pictures. Thanks
JD
Some of these pocket watch cases have springs fitted inside the case, you press down on the button and they open, the spring might be also at fault, but normally it's a strain on the silver hinge or even a split. A job for a silversmith.
Likely better to source a new case as repairing This case is beyond my abilities to repair at the moment. What I don’t want to do is get too curious and become a silver smith:). I’ll look at it a bit closer.
I'm with clockboy. Try a little soldering! Tinker...think. fix it! You're a retired engineer. Hey if you can cut out a paper balance wheel template to test a balance staff, you can hammer and solder a watch case hinge😁👍
I used a an old spring pin once to fix a hinge. It worked. I'm no silversmith either..
If this was my watch, no issue. The problem is that it is not and I would want to practice a lot before attempting this repair.
    • Not exactly John , just have a read through and give us your thoughts.
    • Yep, i pulled that up as well when i was looking,  there is definitely parts out there if you are prepared to go out and find them.  I watched that video years ago, I'm not so sure about probing the coil like that. If you are going to touch the coil use the side of the probe or at least shape a nice round end to it.
    • Hi and welcome to the forum.   As you are already familiar with watches the attachment you may find useful Witschi Training Course.pdf
    • I saw this listing from Australia this morning on Ebay, it might be your only option, good luck.... https://www.ebay.com/itm/145735044565?itmmeta=01HWCRFPEYDDTCXYCRX7ESQH3K&hash=item21ee7c4dd5:g:f2oAAOSwaMhmI5tq&itmprp=enc%3AAQAJAAAA4PzZAWzJj0HOwVM7Xl6qUqGIYly3BvZhzNybkxWf8GJYkKwVh0SpeZ0XYBmoZyjaboPOlJYzdY9svwhQXfR7V%2BiMApTEYFLvJcs8FxTzy1VFCBLR8ADc7V89%2B%2FYvQKdks2KDNNEqAFZN0Hni9zQG078wKL34x0eRK%2Fu843fYdH%2FVIAiOZ5%2BbOmySNdu%2Bv4cSemywC%2FWfaiI%2Fj5D3YWk2PaySdPfu7lUaMadcyhmHZM6l6NllJd1eK%2BdblkJD98pTzVuxRDne5AQaCYawls%2FaoQK9B7epV%2B87TIbD9Ulr4qdC|tkp%3ABk9SR-rnvpjjYw
    • Hi. In the picture not only does it depict that the wheel is bent but also the plate or is that due to th angle of the picture.  Already received very good advise so I will butt out.
