Fhf 186 repair
I bought another non runner, it had I was told a broken staff, so I thought I'd have a go, as I do.
There are quite a few variations, so I've since found out, but then for a watch that was made from the 40s or there abouts there bound to be.
My original broken watch has/had an overcoil hairspring, that was pretty bad, the staff was broken and the lower jewel and to make matters worse so was the escape wheel jewel hole and the bolt spring is broken.
As luck would have it I've a donor, well bits of a donor, it consists of a tube with a disassembled balance wheel with a broken staff, and the movement in pieces.
I haven't done a staff for years, so I actually enjoyed it, the balance wheel didn't exactly fit as I had to open the balance wheel to fit the new staff, but what a wonderful tight fit.
Anyway as in the last picture you'll notice it's going like a train, not bad for a 80 year old piece.
Hi @antonyh,
How did you elaborate to open the balance wheel to get a tight fit, did you drill on a lathe?    would broaching free hand work?
TIA
I simply opened up the wheel with a brooch a little at a time, got it so that I had to push it onto the staff, then tapped it into place.
I really haven't done a lot of this sort of work for a while, sitting there with my Rhonda staff book out on the kitchen table, trying to get all the measurements correct.
When I was looking through all the staffs that I have, I look on some of the smaller staffs from some of the smaller watches and think that a few years ago it was the norm to replace a staff, where as now days you would throw the movement away and just buy a new one.
Edited by antonyh
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
    • Yea a have given it a full service this movement is chinese 2813 whats the lift angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?   Hi you said my lift angle is default how do a remove this from my timegrapher?
