Hook & Spike Clock - Richard Savage
rodabod
Picked this up yesterday as it looked fairly interesting, and I don’t have any very early clocks. I think this one is early 1700’s.
Loomes showed a similar long case clock by the same maker here:
https://www.brianloomes.com/collecting/sleeper/sleeper.html#movement
The clock appears to be very dusty and the oil looks gungey, but otherwise seems ok.
Presuming this is 30hr, but I don’t actually know for sure yet. The weight which it came with has a small hook to the top, so was not sure if this should attach to a pulley. It came from the house of a deceased relative.
I’ve taken off the bell for the photos and the pendulum is not in the photos either. Oddly, the pendulum measures 110cm, so not sure if it’s a seconds pendulum or not - I suppose I can do a train count when I have it apart.
Has someone filed those spikes round, they should be pointed. I would say they are not the original ones. No way are those going to stick into a wall.  Pendulums rods on these clocks should be very long,  more than likely a 30 hour duration.  Looks like cast plates so don't clean them in an ultrasonic it will cause stress fractures and don't expect it to come gleaming and shiny.
The clock has a later bracket mount for attaching to the wall, so presumably the spikes were adapted for that reason. I’ll probably use the bracket as well, as I don’t want my wall getting scratched.
I won’t let anything near the ultrasonic. I probably won’t use anything ammoniated, actually.
The plates I think are cast iron - I think it was mentioned somewhere that this was common on Savage’s clocks.
I'll have to compare it to other hook and spike examples from the same maker. There may also be a difference in the configuration of the top and bottom plates compared to the long case models.
    • I would try the vapour treatment very simple just a simmering pot of the stuff and jewels bluetacked ( not whitetacked this time, you still haven't said if I'm forgiven yet 🙂 ) to the underside of the lid. You're now gonna tell me that stearic acid can be highly explosive above 90° C 🤣
    • I guess it also depends on the precision and quality of the watch. He works on vintage watches mainly and surface treatments on 50 - 60 year old watches probably isn't going to make much difference. I read about nano coatings for car finishes. The article claims that nano coatings can reduced the coefficient of drag by 5%. Is that number significant? I don't know. Maybe if you were trying to break the land speed record. But applying that on a 50 year old clunker isn't going to make it go any faster, accelerate better or save on petrol. 🤣
    • 😅 yep certainly overdid it , i wasn't sure if i had enough heat so i went out and left it cooking. You can see the thick frosting, bit like my cherry buns.
    • 5 hours! You have slow cooked it! It must be really tender by now. @nickelsilver posted about his Greiner machine a while back. It had a heated chamber of stearic acid to epilame jewels and it only took 60 seconds. I've tried stearic acid dissolved in ethanol with a flake of shellac. I'm not really convinced by my test results. I conducted a side by side test by coating a mirror with a stripe of stearic acid and putting several drops of 9010 on the treated surface and untreated surface and observed it for several days. The 9010 spread out about the same for both the treated and untreated surfaces. I spoke with my mentor recently regarding epilame and lubricating pallet jewels. He has stopped doing both because he finds no significant improvements to the end result.
    • Used with the correct fitting staking punch it will remove the roller.
