Main Spring Winder
RogerH
5 hours ago, RogerH said:
Hi Folks, it's the same old topic that keeps coming up but as it's one of the most potentially dangerous part of clock repair I always think it's worth a visit just to get peoples opinion on what is best.
I've just seen this on Ebay....thoughts please -
https://www.ebay.co.uk/itm/303954191633?hash=item46c514e511:g:940AAOSwLG9gjRC2
I have one exactly the same, it's the Ollie Baker style.
Mine has been used on Westminster chime clocks and 400 day clocks, not tried it with fusee springs, because I haven't worked on one yet.
The winder MUST be clamped very securely to the bench before use, mine is held in a large woodwork vice.
Bod
1 hour ago, oldhippy said:
This is the sort I had and it will remove the biggest fusse springs and put them back in. Just make sure you have a good bench vice.
 https://www.cousinsuk.com/product/mainspring-winder-bergeon
On this style without the retaining barrels, how do you hold the end of the spring when transferring into the barrel?
51 minutes ago, RogerH said:
Thanks OH, that does look a bit more like it. does it come with the barrels? or do you buy them separately.
You don't need barrels with this type. You wind the spring up inside the barrel and unhook it with a pair of pliers, I used long nosed ones. Putting it back, you wind the spring up enough so the barrel goes over the spring, making sure it hooks on the inside, you switch the click over so it unwinds and you are finished.
Ha,ok, that's what I thought. Ever have one slip out of the pliers? ?
Not wishing to start a new topic but on a similar vein regarding Main Springs I recently had an Ansonia mech in with two broken main springs - not too sure of the story behind it but they were both split in various places. I replaced them both with new springs of matching width and depth - a bit hairy hence my first question about winders! but it all ran and chimes very well, however, the chime train runs down very quickly - about 3 or 4 days where as the time train appears to be a standard 8 day.
Is there a difference between the springs? They both looked to be the same. is there something else which might cause this? or do they often wind at different rates. I've attached some before pictures. stupidly I didn't get any after ones but it cleaned up really well.
The springs should run down at the same amount if the clock is 8 days the time should last for at least 8 days and so should the strike. Both springs should be the same size and strength. Are you sure the strike side isn’t acting up such as striking when it shouldn’t, striking more then the designated amount.
Hi OH, no, it chimes perfectly. I completely stripped and cleaned the mech and manually wound through the hours with the strike hitting the hour and half hour perfectly. When it's running it's running fine but after three days you need to give the chime side an extra wind up. as the time train runs ok I can only assume the size and strength of the spring is correct. I wonder if there could be some drag causing the chime spring to have to work harder? I didn't see anything originally but I'll strip it again and have a look.
No, it seems to run down quicker. So it's unwinding correctly but at a faster rate than the time side. Thinking about it, I wonder if it's not unwind completely. May be it's sticking so it's not the strength of the spring but something that's causing it to snag and not unwind fully......I'll know more when I get it on the bench.
I think I can now close this topic - unless anyone has any other advice on winders - but I got the Ansonia mech on the bench and looking at both springs, when I fitted them I didn't have the ends fully down against the plate so as the spring unwound it was rubbing against the wheel. I've attached a pic to show the mech with the springs now in place and an arrow pointing to where they were. I'll keep it running but I'm fairly confident that was the issue.
I suspect they used an incorrect key at some point (Or pliers!). The key with it now is worn but it works well enough. The fact both main springs were snapped suggests there's an interesting story to tell but I guess I'll never know!
Another question on this topic. I'm working on a clock with two barrels both appear to have thr spring soldered in place! See pics. The whole clock was very gunged up so I would like to clean the springs but not too sure how to if I can't get the things out of the barrel.  Any thoughts?
    • Thanks everyone for your helpful replies. I think between us we’ve worked out what’s going on. Next job is to have a proper look at this great wheel assembly, see if I can remove the clip and the friction fit pinion, give the bits a good clean, then put it back together with a bit of blue grease. I’ll also get the pallet fork under the microscope to see if it’s ok or been damaged.
    • The cannon pinion (be it conventional style or what you see in this movement) should slip on its arbour so the hands can be set independently without affecting the gear train.  If there is too much friction between the cannon pinion and the second wheel, turning the hands to set them backwards can sometimes force the escape wheel teeth to overrun the pallet stones, creating the behaviour you describe. The train is running in reverse when this happens.  This can often chip the pallet stones. I’d say at least half of the watches I’ve inspected with very tight cannon pinions had chipped pallet stones. Hopefully this isn’t the case with your watch.  I’m not familiar with this movement but you need to get the friction in the cannon pinion adjusted correctly.  Hope this helps, Mark
    • Pallet fork was in. I’d had the movement running ok, and only removed the balance to flip it over and install the keyless works and date mechanism. The pallet fork wasn’t locking the gear train when hand setting - it was oscillating as the escape wheel rotated. This may have been in one direction only - can’t remember.
    • Hi   Find attached parts/repair notes for the JLC 911,  might be useful. JLC_JLC 910, 911.pdf JLC_JLC 910, 911 Repair Notes.pdf
    • Hello and welcome to the forum Dan. Used to know Middlesboro quite well, that was twenty years plus ago. Attached a little reading to get you started. TZIllustratedGlossary.pdf
