Oiling a movement.
Hi some manufacturers do provide lubrication charts for their watches as specific parts require specific oils and greases. The EB 8800 sheet does not (attached) but I have attached the BHI publication regarding watch lubrication. Also attached is the recommended lubrication chart explaining which oils go where. Hope this helps and is of interest.
BTI-The_Practical_Lubrication_of_Clocks_and_Watches.pdf 2849_EB 8800etc (4).pdf _RecommendedLubricantsforGettingStarted.pdf
Thank you. Very much appreciated.
In case of pin pallets, oiling and epilame escape teeth and pallets matters the most.
Modern oils are superior in quality to anything used back when EB8800 were made, so your general lube exceeds requirements.
    • No matter what I did, I could not get the amplitude more than 240 deg. At least there is 0.2 beat error and minus 1-2 s/d.  So, probably not the happy end I would have hoped for, but still I think the watch turned out quite nice. You be the judge of that. Thank you everyone for your help!
    • its used to lengthen or shorten the suspension spring from the front f the clock dial, this in turn will give regulation to the clock. Try inserting a pocket watch key or even better the double ended key for the clock into the small aperture on the dial at the top and turning it, you will see the suspension block either raise or lower. If it raises the clock will run faster if it lowers the clock will run slower
    • Grateful for info regarding the nature & function of the horizontal cog and the unit it's on top of in the picture. It meshes with a vertical cog (enclosed in the unit) on the arbour which is supported at its other end by the back plate of the dial unit to which it is not quite perpendicular...
    • does anyone knows what type of battery this digital Watch takes?
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
