Smith Astral clock in need of a new escapement wheel
DAI
Hello,
I am hoping someone will be able to help point me to a source of a new escapement wheel for my Smiths Astral Air Ministry clock.  It was running fine until it stopped!
On investigation, it seems the adjustment (meshing screw?) on the rear end of the first wheel had backoff slightly and permitted the escapement gear to disengage with the first wheel allowing it to free spin until it happened to re-engage and crash the escapement, break off the lower pivot.  It also dislodged one pallet, which I have since refitted.
However, I am having trouble locating a spare (new or usable) escapement wheel.  Can anyone help me please?  Thanks, David (UK).
1784930867_Screenshot2021-04-15at12_49_45.thumb.jpg.28c80e8f53f7501e568d85956377ade2.jpg
Edited by DAI
typo
  • DAI changed the title to Smith Astral clock in need of a new escapement wheel
I would think that if you can find a good clockmaker, it should be a fairly straight forward repair to drill the arbor and press in some material and machine a new pinion. I have seen a video on YouTube of Mark doing that for a watch arbor so it should be easier for a clock arbor I would think?
Edited by Michael1962
Ah. You hadn't mentioned that.
As it is the escapement wheel and so is not undergoing a lot of torque, is it possible to solder the crack? That may quite well not be the preferred way to repair it, but might get you going while you look for a new one?
Did either of the pallet faces get chipped when the escapement 'crashed'?
Thanks Michael.  I didn't mention it, as the crack was not particularly visible and certainly the lesser of the damage.  I take your point about the pivot repair and could be a temporary solution.  I don't believe the cracked arm is repairable.  The wheel spins almost perfectly true with minimal distortion.   As you mention, it is a low torque wheel with three good arms, so might be fine.
Regarding the pallet; I can not see any damage to the pallet.  It is remarkable that so much damage to the pivot and wheel arm was caused, whilst a dislodged pallet seems fine.  It is now resecured and I am confident it will perform ok.
I am hopeful someone might point me towards a replacement escapement wheel.  A simple replacement would return the clock to fine fettle.  The movement is otherwise in excellent condition (Astral EW.157).
Edited by DAI
20 hours ago, DAI said:
Hello,
It will be extremely difficult to find a replacement wheel but you might be able to find a donor movement on eBay. This is a pretty straight forward repair for a watchmaker who would just re-pivot the wheel.
I would still pick some brains of the people on here as to what can be done. I would have thought soldering then shaping would be a fairly easy task? I would be looking at slightly 'V'ing out the crack, soldering and then reshaping.
The pivot is a different issue, but a clockmaker should be able to do this I would have thought?
https://www.google.com/url?sa=i&url=http%3A%2F%2Fwww.greenfieldclockshop.com%2Fclocks%2Fsmiths-astral.html&psig=AOvVaw3hRXKq-mWmzrp6oCgAbyD4&ust=1618754173260000&source=images&cd=vfe&ved=2ahUKEwjk5omtt4XwAhVMYBoKHRdVBDYQr4kDegUIARD1AQ            I believe its an ABEC platform the above site I think would be able to help. I have a few bits of these platforms. I have rebuilt some from scrappers in the past so all the bits seem to interchange ok. If you get stuck Give me a PM and we shall see what i can turn up     cheers.
    • No matter what I did, I could not get the amplitude more than 240 deg. At least there is 0.2 beat error and minus 1-2 s/d.  So, probably not the happy end I would have hoped for, but still I think the watch turned out quite nice. You be the judge of that. Thank you everyone for your help!
    • its used to lengthen or shorten the suspension spring from the front f the clock dial, this in turn will give regulation to the clock. Try inserting a pocket watch key or even better the double ended key for the clock into the small aperture on the dial at the top and turning it, you will see the suspension block either raise or lower. If it raises the clock will run faster if it lowers the clock will run slower
    • Grateful for info regarding the nature & function of the horizontal cog and the unit it's on top of in the picture. It meshes with a vertical cog (enclosed in the unit) on the arbour which is supported at its other end by the back plate of the dial unit to which it is not quite perpendicular...
    • does anyone knows what type of battery this digital Watch takes?
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
