Smith Astral clock in need of a new escapement wheel
DAI
Hello,
I am hoping someone will be able to help point me to a source of a new escapement wheel for my Smiths Astral Air Ministry clock.  It was running fine until it stopped!
On investigation, it seems the adjustment (meshing screw?) on the rear end of the first wheel had backoff slightly and permitted the escapement gear to disengage with the first wheel allowing it to free spin until it happened to re-engage and crash the escapement, break off the lower pivot.  It also dislodged one pallet, which I have since refitted.
However, I am having trouble locating a spare (new or usable) escapement wheel.  Can anyone help me please?  Thanks, David (UK).
1784930867_Screenshot2021-04-15at12_49_45.thumb.jpg.28c80e8f53f7501e568d85956377ade2.jpg
Edited by DAI
typo
  • DAI changed the title to Smith Astral clock in need of a new escapement wheel
I would think that if you can find a good clockmaker, it should be a fairly straight forward repair to drill the arbor and press in some material and machine a new pinion. I have seen a video on YouTube of Mark doing that for a watch arbor so it should be easier for a clock arbor I would think?
Edited by Michael1962
Ah. You hadn't mentioned that.
As it is the escapement wheel and so is not undergoing a lot of torque, is it possible to solder the crack? That may quite well not be the preferred way to repair it, but might get you going while you look for a new one?
Did either of the pallet faces get chipped when the escapement 'crashed'?
Thanks Michael.  I didn't mention it, as the crack was not particularly visible and certainly the lesser of the damage.  I take your point about the pivot repair and could be a temporary solution.  I don't believe the cracked arm is repairable.  The wheel spins almost perfectly true with minimal distortion.   As you mention, it is a low torque wheel with three good arms, so might be fine.
Regarding the pallet; I can not see any damage to the pallet.  It is remarkable that so much damage to the pivot and wheel arm was caused, whilst a dislodged pallet seems fine.  It is now resecured and I am confident it will perform ok.
I am hopeful someone might point me towards a replacement escapement wheel.  A simple replacement would return the clock to fine fettle.  The movement is otherwise in excellent condition (Astral EW.157).
Edited by DAI
20 hours ago, DAI said:
Hello,
It will be extremely difficult to find a replacement wheel but you might be able to find a donor movement on eBay. This is a pretty straight forward repair for a watchmaker who would just re-pivot the wheel.
I would still pick some brains of the people on here as to what can be done. I would have thought soldering then shaping would be a fairly easy task? I would be looking at slightly 'V'ing out the crack, soldering and then reshaping.
The pivot is a different issue, but a clockmaker should be able to do this I would have thought?
https://www.google.com/url?sa=i&url=http%3A%2F%2Fwww.greenfieldclockshop.com%2Fclocks%2Fsmiths-astral.html&psig=AOvVaw3hRXKq-mWmzrp6oCgAbyD4&ust=1618754173260000&source=images&cd=vfe&ved=2ahUKEwjk5omtt4XwAhVMYBoKHRdVBDYQr4kDegUIARD1AQ            I believe its an ABEC platform the above site I think would be able to help. I have a few bits of these platforms. I have rebuilt some from scrappers in the past so all the bits seem to interchange ok. If you get stuck Give me a PM and we shall see what i can turn up     cheers.
    • But it also makes it seem less susceptible to gravity. If you place a droplet of oil on an epilame-treated surface the droplet of oil will still stay in place even if you then flip the surface from a horizontal to a vertical position. That is, the oil droplet remains anchored, and that's the purpose of epilame. If it was just a matter of creating an oleophobic surface we could probably use other, less expensive, methods!? I don't know @Waggy but my gut feeling tells me you're spot on (pun intended!). I believe the oleophobic property is a side effect of epilame which is designed to keep the oil anchored.
    • Saturday morning 27/4 Sunday evening 28/4 Monday evening 29/4 Floor has a drain in the middle so I am hoping that there is very little fall on it, if any. Room is about 2.5 x 2.5 metres square. Can only use about 1/2 of one wall on the right of the pictures which has a sliding glass door in it. And only about 3/4 of the wall to the left of the pictures as it has the door to the house in it. Progress. 🙂
    • This makes much more sense now, the oil is withdrawing itself to make as little contact with the epilame as possible. Same principle as wax on a car creates a hyrophobic surface that makes the cohesive properties of water molecules pull together.  The water beads run off only when under the influence of gravity but still remain cohesively beaded up. And as mentioned earlier a pivot would keep the oil in place on a cap jewel.  Epilame on an escapement would be a different scenario, there is nothing to hold the oil in position if gravity tugs at the bead to move, plus the escape teeth pull the oil about Maybe this is why its suggested to run the watch for a short while to remove the epilame to make two oleophobic surfaces either side of the oil, creating a ring of fire 🔥 around it 😅 The oil is repelled by every surface of the epilame even that which it sits upon. So the oil pulls together to make as little contact with it as possible, but the oil cant float above that area, it can only sit there on top of it. Under gravity the oil could potentially run away as an oil bead, unless the epilame has an adhesive property which i dont think it does ? So something else keeps it in position ie a pivot under a cap jewel . But that isn't the case in a pallet jewel situation.
    • As with every skill it watchmaking, it takes practice. Notice at the top of the document it says, "Practical work - 40 hours".  I can get the balance wheels 'close enough' to flat, but never seem to get them perfect. Same with gear wheels. Guess I need more practice.
    • Has it got a beat adjustment on the platform or is it a fixed hairspring? in short what you are looking at to get it just about in beat is to get the roller jewel sitting dead centre between the banking pins. So remove the platform and take of the pallet fork and escape wheel to give you clear line of site, sit the platform with the balance in place and with it level look between the banking pins and see if the roller jewel is sitting between them, if it is nice and central its there or there abouts in beat, if its not the the position of the pinned end of the hairspring needs to be adjusted to move the roller jewel into the correct position, thats why I asked if it has an adjustment on the platform or not, if it has its an easier job.
