Bertucci field watch crown release
Hi,
I need to replace the hands on my bertucci field watch and can't seem to locate the crown release. I was wondering if anyone Has experience of these before I start prodding bits!
I've attached a photo of the inside below.
Thanks for any help you can give.
Your watch uses the most popular Miyota quartz module. The stem release point is the small round point, left to the round setting lever post, which is left of the stem itself, near to the bottom.
Thanks @jdm. It was slightly stressful doing this for the first time. I wouldn't have wanted to do it on a watch more expensive than this!
Found the little dimple - you need to apply a reasonable amount of pressure and the crown popped out. For anyone who is interested, you can see the release here:
The second hand presses back on easily, and pops into place. This one dropped off when I dropped the watch face down on a hard floor. These watches have a deep bevel and tough glass, so no other damage.
Quite enjoyable to be able to fix it, and saved me another 15 quid to have it done. I used a rubber ball to remove the screw back and some fine tweezers to press the mechanism, so it didn't cost anything.
Job well done.  I have much respect for the Miyota movements as well.  Two of the watches my daughters wear have Miyota modules in them.  And though I try to instill in them a respect for timepieces, my daughters are not gentle.  They are very active out-of-doors.  Their watches often lead a hard life.  The cases are thick and stout, but they get knocked about quite a bit.  Yet they've never needed anything but a battery change, light cleaning, very little oil, the usual stuff.  Robust little quartz things, those Miyotas are.
I do happen to replace failed Miyota modules at times, two in the last weeks. I don't investigate about the cause or exact failure, at €5 each it's really no big deal.
    • Couldn't see it on the tech sheet , picture is a bit fuzzy though . Is that to keep the pinions pressed on Marc ?
    • Doctor, If the train turns when hands setting, this means that the train is not blocked. And this is true for all kinds of trains design. The train is normally blocked by the lever. So, put the lever in place and try again. If the train turns again, search where You have placed some wheel upside down and it is not meshed with the next one in the chain. The other thing is the amount of friction that is needed to overcome when setting hands. Yes, the friction part here is in the great wheel, and it needs lubrication. If the parts are dry, then friction will arise, seizing will happen and thus risk of breaking of teeth in the train or breaking of joint wheel/pinion. I don't know this calibre, but I guess the clip is part of the friction device. But for sure it stays tilted, which is not normal. So, pay attention to it and see what is wrong there
    • It most certainly should be there, but it should fit better than that. Here is what it should look like.
    • This way is dangerous. The problem is that the collet is not expected to be perfect in this tool and the wheel used for the grinding is big and easy can touch the balance wheel. Can You show the bottom side of the balance wheel?
    • It shouldn't be attached    The pinions look independent of each other, not in alignment,  but the clip is bothering me or have you just placed that on the pivot end?  Found a cannon pinion maintaining clip in the tech sheet, is that the disk on the end and is broken.  Whatever happened to exploded diagrams 😠
