Junghans?
RogerH
Just as an update, here's the clock so far. the mech runs really well. I've yet to decide whether to replace the pendulum with the R&A sticker - it's just not as nice as a painted one. I've cleaned the case but I often feel it's not right to completely strip and re-varnish etc - it's wear and tear is all part of it's character - but is that the done thing?
My only bug bear is the chime. Despite a new hammer (the old one was worn down to metal) and clean up of the gong (Its the classic spiral type)it still sounds like someone hitting a car roof with a spanner! can anything be done about that? or does this type of clock not have a lovely deep chime tone?
The type of case sometimes can cause the strike to sound dull. Any splits in the wood won’t help the tone.  Try moving the hammer away from the gong or if the hammer is on a rod move it back a fraction. If the new hammer is hard that can cause problems, if you are able to soften the material it is made out of paint some oil on it to soften it up.
Hi  The clock looks nice, I personally do not strip the wood and re varnish. I got like that in life its part of the character of any clock.  clean it and beeswax and elbow grease should do.  Spiral gongs differ I have three clocks with them and all sound different. As OH says the type of wood and condition of the case can make a difference. As said try the tricks with the hammer should be leather.
    • Thank you!   Yes I did. I did not notice a difference. Although 9415 is advertised as a thixotropic grease (and I did had high hopes for it), the only advantage at this point I see is that its “easier” to apply than an oil (if one does not use epilame). But this is subjective, I guess. What I did notice though, if you apply a bit too much grease, that definitely slows down the movement. Oil in this case is a bit more forgiving, as its super thin, and it would usually just spread out.  Again, imho.
    • Mark keeps a close eye on his forum. I'm sure if you asked him he will reply, he might not do it right away but you will receive his answer.
    • I kind of think the same, the surface under the oil is the same as the surface around the oil. Can epilame both repel and attract , that doesn't quite make sense in simple terms, but is it more complicated than that. When cohesive forces within a liquid are stronger than the adhesive forces of a surface then surface tension is high causing the liquid to bead up. So  an applied epilame coating reduces the adhesive force of a surface inhibiting a fluid to wet the surface. So i guess no epilame cannot both repel and attract . If something is keeping the oil in place on top of an epilamed surface then there must be another reason for that.
    • I agree with @JohnR725. Oil on an epilamed surface is essentially the same as water on a waxed surface. The same physical properties are at work (surface tension vs. adhesion).
