I have never understood how a square can be produced on a lathe, seen plenty of videos but not sure how it works. How do you make the huck on the arbor? -
personally from my point of view I would say no. This is where more than just an evaluation on one side is needed somebody needs to take the watch apart and see what else is bad. Like it's possible the pivots for those wheels are missing which we really can't see in the picture right now. Then that does appear to be rather heavy rust on the balance bridge and I wonder where else were going to find that rust? just a little clarification here are you new to working on an Omega 1010 watches or are you new to working on watches altogether? The reason I need the clarification is that if you're new to watches and even if this watch came to you for free repairing it is going to be extremely expensive as Omega watches tend to be very expensive for spare parts. you never can tell about watch companies what part numbers we can find.of course the biggest problem of all is this is Omega watch part of Swatch group and Swatch group doesn't like us so they're not going to sell you the spare parts unless you have a swatch account. then if you have to find aftermarket Omega parts because they know that nobody can get those parts that tend to be really expensive is why repairing Omega watches is going to be very expensive. According to the parts list found at the link below there were some jewels available I'm not sure if they're the right one because I haven't quite figured out which jewels those are yet. I'm also attaching a PDF of the parts list to help you identify whatever it is you're going to need it looks like some of the plates were once available although getting a new plates will be problematic it might actually be better to find a scrap watch to steel parts from. http://cgi.julesborel.com/cgi-bin/matcgi2?ref=OME_1010 Omega 1010_complet_2236.pdf
By eccentric59 · Posted
You mean all that stuff about aliens and black helicopters isn't true? -
Thanks yes it’s nice to make tools and equipment if we can , I needed a fixed steady for my Pultra I had one for a Pultra with 70mm centre and I was going to cut it down to be able to use it on my P type ( 50mm centre) but it seemed a shame to butcher such a rare item so made one. Dell
Go and drill with 0.4, then finally turn the piece to size untill it fits the hole. Don't worry, if something happens, You can turn new arbor.
