Hi all,
I figure these movements were kind of popular and expensive (they are still available). So, since I just saved US$104, the price of them this side of the pond (take or leave a few dollars) I wanted to share my experiences.
First off, the service data:
233_Seiko5M42A,5M43A.pdf
Now for the disassembly:
My order here is a little odd. The movement was in bad shape being an ebay non working watch, just for the exercise at hand. Therefore, sometimes in order not to damage a part, i.e. circuit or coil mainly, other parts are being taken out of the way first to facilitate the disassembly. In some pictures, there is another similar movement which also was used to eventually put together a working one between the 2.
So, here is the 5M42, notice that the 5M43 only adds the day disc, a selector gear we'll mention later and a disc holding clip. Everything else is the same. The new capacitor kit that replaced the bugged original one is: 30235MZ which is also good for the following movements:5M62 and 5M63.
post-253-0-85781500-1428281213_thumb.jpg  post-253-0-64776100-1428281215_thumb.jpg
There is no capacitor present in this movement...
Notice that this movement can be disassembled each side without interfering with the other side. This means that we can remove all the parts from one side and then turn it and remove all the parts from the other side. Your choice which side you want to start first. I prefer to remove the rotor and keep going on that side (bottom) to ensure there is no damage to the rotor screw and bearings. As an added advantage, I'm also minding the coils and circuit.
I would have removed the capacitor clamp, insulator and capacitor unit. This is only possible after the previous step and before the one being illustrated below.
Removing the circuit block cover:
I also removed the oscillator weight (rotor) bridge first since the circuit seemed kind of stuck and wanted more visual/elbow room to tackle it:
A closer view of this bridge, notice the intermediate wheel for generating rotor:
Now we have a full view of the electronics, in very delicate estate I may add. Luckily the circuit block is OK ( I used the one from the other movement which was in better shape ):
Then, goes the short coil...and the long coil, the generating rotor and generating stator:
post-253-0-14471000-1428281319_thumb.jpg post-253-0-00756400-1428281322_thumb.jpg
post-253-0-24790600-1428281324_thumb.jpg  post-253-0-68152400-1428281325_thumb.jpg
We remove the only screw holding the train wheel bridge and look under the "hood":
post-253-0-03453800-1428281328_thumb.jpg post-253-0-94830700-1428281329_thumb.jpg
Here is the underside of the train bridge. You are seeing the setting wheel still stuck to the bridge:
In the following pictures we remove the fifth wheel and pinion, fourth wheel and pinion, third wheel and pinion, step rotor, minute wheel, center wheel and pinion...
post-253-0-24524500-1428281333_thumb.jpg post-253-0-60828600-1428281334_thumb.jpg
post-253-0-11620600-1428281376_thumb.jpg post-253-0-81724300-1428281377_thumb.jpg
post-253-0-36988400-1428281379_thumb.jpg post-253-0-83454200-1428281380_thumb.jpg
Then we proceed to the keyless work et al. Removing the train wheel setting lever, switch lever (careful is under tension), setting lever, capacitor connection and yoke:
post-253-0-63786300-1428281382_thumb.jpg post-253-0-09850600-1428281384_thumb.jpg
post-253-0-83605100-1428281385_thumb.jpg post-253-0-19124200-1428281387_thumb.jpg
We discover underneath the clutch wheel and remove it. Also the rotor stator is removed:
post-253-0-69766600-1428281461_thumb.jpg  post-253-0-29324900-1428281463_thumb.jpg
At this point we turn over the movement...or what is left of it:
As you see this one is the 5M42 version without the day disc feature. Normally for the 5M43 we pry, carefully with a small screwdriver, the snap for day star for dial disk, the day star with dial disc and the intermediate wheel for day correction. All those parts are similar in shape and location as to the 7S26 mechanical movement so there is no need to illustrate it at this point...if we had gotten it. Note that this movement uses a dial washer.
So we skip the day star and start removing the date dial guard and date dial:
Underneath is the familiar date jumper reminiscent of the Seiko mechanical movements, date driving wheel, intermediate wheel for calendar correction, date correction setting wheel, and hour wheel. I'm not sure about the plate present in this movement, it might have been one of those franken things, but this plate doesn't have the non-removable antimagnetic shield plate. I used the donor movement main plate since it had it.
Here is a picture of the movement using the antimagnetic plate:
So removing each mentioned part:
And voila! The bare plate:
Now we only need to remove the holding ring for dial and dunk everything in the cleaner...NOT everything! The generating rotors, both coils and circuit block DON'T go in the cleaner! Nor would go the capacitor if we had one in this case. Everything else is fair game. One note of caution, while assembling use plenty of rodico for each part since magnetism is an issue and can attract undesirable particles into the movement. Always check and recheck!
From this point on and after cleaning the parts. Assembly is simply a reverse order. Follow the technical data for lubrication...I simply used moebius quartz oil and simplified everything...and maybe a little Seiko S6 here and there, mainly keyless works.
One important data for those who don't have a multimeter and want to check the coils. You are measuring 2 different ranges of resistance/impedance, if your meter is not autoranging, make sure to change the range accordingly.
Here is the final product in its case and with temporary hands...until I get something I really like and can refinish the case.
I also forgot to say that this movement uses hands: 65/110/20...so far difficult to find in sport, luminic types...or so it seems from trawling the net!
Hope all this helps! Enjoy!
Cheers,
Bob
PS. Any insight, corrections, suggestions, etc is most appreciated!
That's correct icius, I believe that's the name for the same movement by Pulsar, a Seiko division. Thank you for the nice words!
By the way I'm editing the above to add something I forgot!
Cheers,
Bob
And this is why kinetic service prices usually aren't cheap.
Watch looks nice as it is, but I wouldn't mind seeing it refurbished with your final choice of hands.
Very interesting, thanks for the post, bob.
Edited by Ishima
I echo Ishima's words Bob!
Very informative, and thanks for taking the considerable time to photograph and document the journey. :)
  • 8 months later...
Hi Bob,I wonder could you help me please, my watch was working OK but thought it was about time after 10 years to give it a service
Seiko wanted about £100 to give it a service
I am not very well versed in watch repair but thought after seeing your guide I should be able to do it
I removed the train wheel bridge but cannot get it back on the wheels just wont line up, spent 2 days on it but not getting any where
Took watch to a watch repairer but now I have taken it apart they wont touch it
could you possibly give me any hints on how to get the bridge back on
I don't want to as I am attached to the watch, but if I cant get it back together, will put it on ebay for spares repair
Many thanks Nigel (UK)
What  a great job you have done Bob :)  . Lots of small parts in that movement! Interesting movement with rotor and electronic parts. It's like a mix between an automatic and a quartz?
@nigel: All I can say Nigel is don't despair and have lots of patience. Make sure the wheels are perfectly aligned on the bottom plate before you attempt the upper bridge, be gentle and test often. Tiny parts and small pivots...still quite resilient for the size but not bullet proof so they can be broken and rendered useless...so care and patience is the recipe!
@rogart: That's correct rogart, the mechanical section of the movement resembles in principle an auto movement, with weight and all that turns a tiny motor which in turn charges the capacitor. It all boils down to provide electricity to the quartz that makes this type of watch very precise. I particularly like this version better than the "sun powered" types (from either Seiko or Citizen) since as long as there is movement you have power. One thing that makes this movement, like all electronic/quartz movements, a "problem" is the coils that can be easily damaged. I wonder why then don't encase them or protect them better...one slip of the screwdriver or tweezers and bye, bye coil!....or buy, buy coil :)
Thank you and I'm glad this walkthrough has been found useful!
Cheers,
Bob
Hi all,
attachicon.gif233_Seiko5M42A,5M43A.pdf
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0214.JPG http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0215.JPG
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0216.JPG http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0217.JPG
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0218.JPG http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0219.JPG
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0220.JPG http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0221.JPG
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0222.JPG http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0223.JPG
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0224.JPG
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0225.JPG http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0226.JPG
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0227.JPG
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0228.JPG
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0229.JPG
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0230.JPG
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0239.JPG
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0231.JPG http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0232.JPG
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0233.JPG http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0234.JPG
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0235.JPG
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif IMG_0238.JPG
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif 20150405_224417.jpg http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif 20150405_224439.jpg
Cheers,
Bob
great job. Amazing how standard the Seiko parts are across types
    • Hi there! You have learned how professional watchmakers feel about Timex. It is very difficult to find one willing to work on them, for a few reasons: 1) a lot of them wrongly believe Timex cannot be serviced, are riveted together. This is a myth. 2) when serviced, they still cannot meet the performance standards of jeweled mechanical watches (-20sec/day is good enough for a Timex) 3) customers are unwilling to pay the watchmaker's hourly bench rates because the watches are worth very little The service manual for the M33 is available at https://heritage1854.com/m33 but you also need the M32 and M31 manuals because they build on each other (31 is the base, 32 has date, 33 has day and date) https://heritage1854.com/m31 https://heritage1854.com/m32 A stuck date changeover can be due to a missing, bent or broken detent spring (part 2576 in the manual) or the date wheel (2556) got stuck or separated from its post, or maybe disengaged from the hour wheel. With a little confidence, these are not difficult to repair and parts are pretty much interchangeable with any other Timex from the same era having the same features. So it is very easy to find inexpensive spares in the form of junk watches (don't bother trying to search for individual spare parts). My recommendation would be to find a junk Timex with an M25 (older manual wind with date) and practice a little with it. Follow the service manual from the same website. The automatics are a bit more difficult to work on but once you get a feel for how they fit together, you can make an attempt at your automatic and you would be able to use many spare parts from the M25 if necessary.
    • I do indeed have some programming and electronics know-how. 3 decades writing code for a living, and playing with microcontrollers as a hobby. 🙂 It helps with my actual living of being a voice actor because I can maintain my own equipment- no one around to replace the caps or the tube in an obscure botique mic that isn't made or supported any longer. Also saves money maintaining and cleaning my own interfaces and mixers when they develop problems in the faders and such. That said... I do have a question that, I'm sure, will betray my ignorance about certain areas that I have yet to fill in. I understand a "WW" lathe is a "Webster Whitcomb", but from what I understand that is a style of lathe and not a brand, correct? If someone would be willing to clarify and maybe expand on the terminology, it would be helpful so I can better understand the advice being given and know what I need to look into to further my knowledge. For example, a Sherline mill would appear to be either a separate piece of gear or an attachment/expansion to their smaller lathe. When you say you have a WW lathe and a sherline mill, can you say exactly what devices you have? Thank you! (I just realized I have a few Raspberry Pis and some Arduinos of various form factors around here I could probably put to good use in a scenario like you describe above).
    • HI everyone Some context: I'm "in love" with old Timex. As someone who has always liked watches, I knew Timex (my first watch and another project) but, in fact, the brand had never really caught my attention. By pure chance I bought, in a set of two others watches, a small m24 that was sold as not working (run and stop), which actually started working by setting the date by manually moving the hands (15 days). This coincidence made me interested in its history, its reputation, simplicity/complexity of the movements and also because some were made in Portugal back in 70’s and 80’s. A few days later I found this beautiful 1975 Viscount, m33 (very low price, almost offered) and this is where I need your help.  It is in very good condition and works well (-20s per day is not a problem for me), and although the day of the week changes correctly, the date is "stuck" on the 10th. I live in a small town that only has one watchmaker and when I purchased this watch (and having read about these movements) I thought that since it was something theoretically "simple" (probably not related to the movement), he would easily solve the problem. I couldn't be more wrong. It was as if I had proposed a pact with the devil. He refused and said he wouldn't touch the watch (although he had serviced several of my watches before - Seikos and old Swiss brands). He suggested I wear the watch like this or trash it. As I mentioned in my presentation to the forum, I have some experience in digital watches, but in manual watches I am a complete beginner. I know how to remove hands, crowns and little else. I've been doing my homework, reading the technical manual and watching a few videos on YouTube. I think I can get to the part of removing the dial without any major problems. I know that in the Date Frame there is a wheel that at the top has a tab that activates the Day Wheel and that at the bottom activates the Date Lever My aim is to try not to ruin anything and  get the date working again. The help I needed (I intend to post photos) is that what should I expect? What are the most common problems that cause this system to get stuck (in this case just the date).   PS -  My secondary objective is to buy a strap at a overpriced value from the watchmaker just to rub it in his face that I managed to get the watch working properly. PS2 - In the photos you can see that before midnight the day of the week is already changing but the day of the month has not changed.   Sorry about the english. Best Regards Vasco
    • What is it from and how did it become bent ? It should bend back - I would heat it whilst bending
    • Ha, same here. I just looked and I've lots of pictures of my cars, be hardly any of me - I have a face better suited for radio. I did find this from about 20+ years ago. I'm the young looking one at the back, under the front nozzle.
