Fixing an omega balance staff pivot
3 hours ago, Tore said:
That was amazing! Did you unhardened(dont know if this is the right word) the staff before drilling?
No I did not. And it would have made a good difference. Because it was quite hard comparing to others pivots I drilled as a pre practice.
What would be annealing the temperature of that shaft?
I messed it up. I managed to make a 0.1mm hole and was perfect. Just had to insert the pinion.
Then I had the brilliant idea to expand the hole to 0.2mm so I could have a stronger base for the pivot... but the drill bit broke inside... so sad.
I almost managed to do it. I think moving forward I will start with a 0.2mm bit, the 0.1mm is a bit overkill.
    • Usually the coiled spring contacts the piezo sounder and the finger spring is the ground.
    • So I checked with my friendly local lab supplier and they can supply the following in 2.5 lt bottles: Tetrachloroethylene (B-Dip) - approx £65 Trichloroethylene (one-dip) - approx £43 n-Heptane 99% (Essence of Renata) - approx £35 Hexane - approx £45 I can't import or buy locally the 'real' products, hence the raw chemicals above. What do you think would be my best option? I'm edging towards Trichloroethylene - I know there are greater health risks, but given the very small quantities used for each treatment and 99.99% of the time it will be sealed in a jar, I think any risk is vanishingly small? This is mainly due to its assumed superior cleaning properties, or from the experience of this group, is the extra cleaning noticeable compared to its safer alternatives?
    • Unfortunately after much investigation, apparently the coil has been discontinued! Shall I get my service guy to try the solder or the conductive paint? 🎨 Final recommendation please🙏
    • Here are the pics of the bridge. Looks correct, but as soon as I screw on the rotor, the watch stops. Video here: https://1drv.ms/v/s!ArG5E62RGctxjokY5ws85BzuJLVakA   Pics. Might have figured it out. I have been working on this watch for a while and since I got it as a non runner in a terrible shape, there was no guarantee that parts were proper. I think the main screw that was used on the rotor was too long, so it was stopping the main train. As soon as I fished out a much shorter and larger headed screw, things were good again. Please celebrate with me.
