Waltham 155 Movement From 1900 - Advice Please
WillFly
I've got a very nice 15-jewel,  Waltham wristwatch movement head, size 0, grade 155, from the year 1900. It's cased but is without winding stem and crown. I'd hoped to be able to get a stem and crown, either as parts or from another "spares or repair" piece.
Unfortuntely, I discovered recently that Waltham didn't, in fact, make their own stems and crowns for this movement - they relied on them being an integral part of the case. So - unless I can find a similar head or case with stem and crown, I'm stymied, and to find one from the same era and size is going to be long  haul job.
Any advice as to progress - or should I just sell it on?
These two parts are made years apart... The movement is designed for a pocket watch case, hunter style. The case is much later, 25-35 plus years and was designed for a purpose built wristwatch movement that has the winding stem integrated into the movement, just like today's watches.
I can see no real practical or cheap way to make this marriage happen. I would punt, IMHO.
Your only other option is to find a 0s American case and install the movement into it. At least you'll have a complete pocket watch, but not a wristwatch.
Sorry.
Will, I have worked on many of these recased American made movements in friction stem wristwatches. Your movement is an American made Waltham 3/0 in size. It appears to me that you need a stem, sleeve (friction type) , and a crown. Some of these cases take a screw in type sleeve and others just fit from the bottom of the case tube. Unless you have an assortment of sleeves and stems for these type of cases it is hard to locate the correct sleeve and stem not to mention the crown. They are nice watches once you finish them, but finding those parts can be a challenge.
Hi southwesttimers- how common are these type of wristwatch cases that used these friction stem/sleeve setups? I've seen one before but it was done aftermarket with a modern type case and a Hamilton 992 movement. It seems to me the sleeve is the most important part of this steup as the stem can easily be turned and a crown can be adapted to fit. Is there anyone selling sleeves for this particular aplication or can a threaded sleeve be modified to work in this situation?
BTW, with the serial number stamped on the movement, 10389186, I get a size 0 in the pocketwatch database, not a 3/0 is my database incorrect?
Thanks!
DJW
Everyone I have ever seen like this has a sleeve with four leaves on it - usually one or two leaves are broken off. I have never seen a screw on type of sleeve on the wrist watch walthams. But I have never found a supplier of the sleeves either.
I have tried to make them but never had good results. I get the shape right and technically it works but I can never seem to replicate the springiness (is that a word). So when doing the hardening and tempering I either get it too soft or too brittle. I'm most likely using the wrong kind of steel.
Many thanks for all the info and advice on this movement - which, I believe, is a straight 0 size according to my Waltham database - it's greatly appreciated. I've actually done a bit of research on this and come to the conclusion - backed up by the evidence of people on this forum - that the game isn't worth the candle for me. If anyone wants to tinker with this for the the cost of the cheapest postage, you're welcome to it. If not, I shall probably put it aside for a rainy day, get my tools and digital camera at the ready - and do my first real teardown... :skydive:
    • I agree with @JohnR725. Oil on an epilamed surface is essentially the same as water on a waxed surface. The same physical properties are at work (surface tension vs. adhesion).
    • I think we all get a lot out of this group, and it has been pivotal in my development by the sharing of knowledge, experience and learning from more seasoned experts such as @JohnR725 and others (you know who you are!) as well as fellow novices. I think that having a backup communication plan in reserve so that if there is a future problem just makes good sense. I don't think anyone is trying to undermine the forum, but if something unthinkable happens, like the Ranfft website for example, then it would be good if those who are willing can still keep in contact. Speaking personally, and I know I risk a charge of heresy, it would be good if Mark could be a little more visible in this forum, and maybe give any insight from time to time on the future/progress of forum and instructional videos etc. even if its just to confirm the status quo. I appreciate he is a busy man with a full time job, but so are most of the rest of us and to post a few lines every now and then shouldn't be too much to ask to reassure the restless villagers. Best outcome for me would be a message saying something along the lines of: "Hi guys, all good, no planned changes... enjoy the forum, will message again next month!" Just my two cents.
    • A nice looking watch !! Did you try 9010, instead of the 9415, on the pallet jewels / escape wheel? And if you did, did you notice a difference?
    • Knocked out another 404 last night...when you are in the zone! This watch was a non-runner which I picked up as part of a lot of 8 watches, so works out to be $3.12 per watch. Before:   And the finished watch, new crown and stem and the crystal was cracked so was replaced. I also replaced the mainspring as the original was the old steel type spiral and very 'set' - all else is original: The Movement was a AS 1686, but in reading around a little the ACCRO watch company were sued for their use of the five point crown on their Jacques Pere range as it resembled Rolex, see below: ACCRO then reverted to just ACCRO on their watches - I have done some sniffing around the internet and haven't seen another example of ACCRO and the crown together on a dial so maybe I have something unusual, or maybe I was looking in the wrong places 🙂.
    • This watch was damaged when I got it. I didn't break the escape wheel pivot, and I bodged a fix with epoxy to see if I could get it running. I'm not yet ready to get into lathe work, or shellacking jewels, and may never be. But I'm learning plenty with each watch I tackle.
