Recently acquired Tag Heuer needs help
GregC
I recently acquired this Tag Heuer S89.206 watch. The rotor was detached which I managed to fix but it has 2 other problems. One is the bracelet clasp is broken and the end links are missing. The number on the clasp is 473/4. Is this the correct number to be searching for? The second problem is the stem goes in and doesnt move anything and comes out back easily. It also doesnt screw down and I dont see anything looking like threads on the outside of the tube. Do you guys think this is the original stem, crown and tube and any opinions of how to fix? Any leads as to where to find the clasp other than ebay? TIA
I'm pretty sure that is the correct clasp number. If you can't rebuild the clasp, my recommendation is eBay. Don't look for just the clasp, but also the whole band. Be patient. It'll eventually show up.
Tag crowns tread on the inside of the case tubes, so you won't see the threads unless you look inside. The crown looks original.
If the stem goes all the way in the movement, but still comes out, you have problem with the detent or setting bridge. Test it when the movement is out of the case. If it stays in then you know the issue is with the stem length or crown/case tube.
Does the band have a different part number ?
3 hours ago, JohnR725 said:
It would also be helpful for you in a picture of the movement. When the movements out of the case you can test the crown on the case without the movement ill make it easier to see if you're having a problem with that.
Took it out and the stem goes in and out so I guess its a candidate for a teardown. Crown doesnt screw down either with the movement out and the crown doesnt look like it has threads.
    • yes I noticed the new site and I miss the old site. It's the unfortunate problem of the Internet here today gone tomorrow sometimes some of the stuff gets backed up and sometimes well it does not then the problem with the early Seiko's were there were not necessarily designed for distribution across the planet and as such there is no customer support for them. So trying to find early stuff like technical information or sometimes even parts list for older Seiko is is problematic. But I did find you a you tube video. A quick look he seems to take a heck of a lot of time to actually get to the service single I did not watch all that but it does look like he did disassemble or started to say there's a tiny bit here
    • RichardHarris123: Hello and welcome from Leeds, England.  I have family all over Australia, went as £10 poms Thanks Richard. Hope you’re able to visit your family here and that they’ve all done well 🙂 My relatives arrived from England in the 1790s transported on the ‘Second & Third Fleets’—a story of timber sailing ships, of convicts and doing well in this huge Country of Australia. When I visited the UK in the 1980s, I was too young to comprehend the depth and breadth of its history…  Best wishes, Mike William Chapman, my 4th great Grandad’s charges, at age 23 read at the Old Bailey; sentenced to 7 years of transportation to Sydney.
    • The whole process and the progress are closely observed, it's hand-driven and very controlled. I can't see the "danger", unless you are watching the TV while doing it. As you could have read, and in this quote "wheel" is the balance-wheel.
