Chelsea ships clock
Danv508
Hi all I was looking for for him to help me identify this clock and give me a little advice on it. My name is Dan I recently purchased this Chelsea ships bell o’clock I can’t find the serial number on the back and when I pull the clock a park there is really no serial number on the back plate either and not even stamped with a Chelsea‘s name. The clock was dedicated to Frank E heart which with a quick Google search shows that he was one of the founders in designing the Internet as we know it today. I’m thinking this clock is very special but I’m not sure on the backside at the top near the mounting screw there’s a number 91 and that is all and then on the inside there is nothing just some marker writings on the top in blue. Please help. Can’t figure out how to insert pictures onto this forum
Morning  Dan, welcome to the forum. You should just be able to drop and drag pictures across. (At the bottom of the text box you write in) and sadly, without them I'm not too sure there's a lot the guys can do. I've no idea btw but I'm sure someone will know.
Dan welcome to the forum. You need to post some pictures for us to analyse
Thanks for the reply I didn’t even see that at the bottom of the page. I love the clock and I am not planning on getting rid of it I was just wondering about what it may be worth being that it was owned by such an influential person. I even went as far as the Google his wife and come to find out she was the first woman ever let in order to become a professor at an MIT laboratory that and a bunch of other things. The clock now seems to be holding pretty good time I let it run overnight still the only problem that I see is that it rings at the wrong time. I’m guessing the clock isn’t all that old probably about 40 years if it is a 1991 it’s just weird that there’s no serial number on it. The back only has a number 91 stamped on the top.
6 minutes ago, Danv508 said:
I’m just wondering what something like this could possibly be worth being owned by such an influential person.
The problem for something like this is to prove it really did belong to that person. The person is important enough that there's probably a history of him somewhere. If there was a photograph of him receiving the clock or a picture of it sitting on his desk preferably with him sitting there. Otherwise it's interesting piece of history but you can't really tie it to the person unfortunately.
Out of curiosity what do you mean that it rings at the wrong time?
OK I understand what you’re saying. First off he did live in Massachusetts which is where the house was cleaned out. Also he did work for that company and he did start as the plaque states in 1966 so I really don’t think I’d have to go any further I guess for $35 I could get the certificate from Chelsea clocks improve it was sold to a company on the plaque. I will probably still get the certificate but I really don’t think I need it everything adds up perfectly. And what I mean about the chimes is that it does not ring on the hour and a half hour it rings yeah let’s just say 1:20 and then the next time that it rings is around 1:50. If that makes any sense.
1 hour ago, Danv508 said:
I didn’t want to have to pull the hands off the clock but if that’s the only way to fix it and that might have to be the route I’m going to go. And what I mean about it not chiming is it rings in the right sequence just in the wrong spot
I have had another look at the pictures of the movement and I could be wrong but if this is a snail wheel then it looks damaged. If you look at french snail wheel it has segments of different lengths that determines the amount of strikes.Maybe if you lift the cam that’s following the snail it might advance to get it into the correct sequence (if it is not damaged)
I don't think it's damaged I think the problem is were not seeing all of it. In other words the rest of the strike stuff is hiding in the back someplace. As a ship's clock it doesn't strike the normal striking It is on a eight hour cycle. it looks like that snail may be set up for eight. Although it's hard to tell.
Then yes it may just be that simple but? In other words of the striking is right through its cycle it's just that your 10 minutes off then the simple fix would be just to move the hands providing you can do that. Sometimes the hour hand goes on a square part and that doesn't like to be moved. But if you're lucky they may both just pull off and just repositioning them solves the problem.
One clue that you may be having a hand not in the correct place issue it is at midnight or 12 noon are both hands together and are the actually pointing to exactly the top of the clock? I'm looking at your original pictured it looks like at midnight you'd be off a little bit. So for instance somebody setting the hands especially if you set them backwards at the wrong time may have actually knocked the hand the minute hand out of alignment. The easy way to fix this is at midnight basically or 12 noon wait until the hour hand is exactly where it's supposed to be and then just reposition the minute hand. Then hopefully be striking at the right time.
Thanks so much for all your help. I did take the min hand off but it’s a square shaft so it can only go on 4 ways. But moving it one position now makes it chime 5 min late. So now it chimes five minutes after the hour. I really don’t want to go digging too much further into the clock in case something goes wrong that little wheel on the back of the clock with the arrow to it appears to only set the amount of chimes that the clock gives off I don’t think it has anything to do with the time the chime goes off. If that makes any sense
    • It looks like the canon pinion function is part of this great wheel. The pinion nearest the clip runs the minute wheel on the dual side. The pinion nearest the wheel is driven by a small wheel from under the setting lever cover plate that engages in hand setting position.    So when assembled the crown was driving the whole great train. Does this mean the pinions are too tight? Should I attempt to disassemble this great wheel and lubricants?
    • Picking up this side-tracked post again as I just removed a balance staff of a 1920's Omega (35,5L-T1) I was impressed by the way @Delgetti had his setup when he had to change out a balance-staff (https://www.watchrepairtalk.com/topic/28854-new-balance-staff-not-riveting-to-balance/page/2/#comment-244054 Not only that, but also the idea of removing the seat first before punching the staff out from the seat-side, avoiding the whole discussion of the rivet yes/no enlarging the hole. I didn't have the fancy clamps & tools Delgetti has, so I used my screw-head polishing tool. Initially I used #1500 grit diamond paste on the steel wheel, which kinda worked, but very slow. I changed to #800 grit diamond paste, which worked better, but still slow. Then I glued #240 sanding paper to the steel disk; That worked and the disk was hand-driven. Once close to the balance wheel, I took the sanding paper off and continued with #800 diamond paste. One can only do this when the balance wheel sits true on the staff and has no "wobble". I went on grinding until I saw some diamond paste on the rim of the balance wheel. This was as far as I could grind and it seemed that there wasn't much left of the seat. Carefully, with my staking set, I knocked the staff from the seat-side out. Turns out that the thickness of the seat left, now a small ring, was only 0.1mm. The balance wheel hole is in perfect shape and no damage done to the wheel at all. Of course, if the wheel has a "wobble" or isn't seated true on the balance staff, you can't get as close and there will be more left of the seat. In my case, it worked perfect 🙂 I'm very happy how this method worked out ! 😊
    • As is tradition, one step forward, two steps back. Got the board populated and soldered into place without any issues.   But no hum. So I started testing the coils with an ohmmeter. I got 5.84k ohms across D1 (from red to red in the picture below), which is as expected. But I'm getting an open circuit for the other drive coil and feedback coil, D2 and F1 (from green to each of the two yellows).   Since the movement was working with my breadboard setup, it implies I somehow broke the connection between the coils and the solder lugs. They're all the way at the bottom of the lugs, but maybe the heat migrated down and broke the connections? I guess it's possible it happened while cleaning the flux off, but I used a soft artist's brush and isopropyl alcohol. I did a lot of high magnification examination, and I don't see any issues, but let me know if you see anything I missed or if you can think of anything else I should check.
    • 1947 NOS Ambassador 'C'. Actually, the case came without the movement so the movement isn't NOS, but she sure is pretty.
    • Hi attached is the AS 20XX. Service sheet although there is no 2063 mentioned it may be of some use to you AS_AS 2060,1,2,6,4,6.pdf
