I am thinking of buying a mainspring winder off ebay that a guy makes out of steel, it was originally by made Colin Walton who designed the original i was wondering if someone could give me some advice or you view.Would i be wasting £170 which he is asking, thanks
It looks workable. Very similar to English pattern winders. I like the screw clamp for gripping the end of the spring. I think that's safer than gripping the end with a long nose plier. Make sure that it has serrations for a secure grip.
However, I don't agree with the square bar portion. When the spring in a barrel is wound until the tail can be gripped, it's not going to be tangentially oriented. I think the clamp should be able to rotate to whatever angle the tail of the spring ends up.
But it should work fine for open springs.
1 hour ago, HectorLooi said:
You may want to consider a Webster mainspring winder. There is one on ebay now that comes complete with containment rings.
will have a look at that HectorLooi
19 minutes ago, watchweasol said:
Hi Willow  If it comes complete with a set of retainers thats good, whats the postage like.   the retainers alone cost me £60 from America.
About £60 £70 postage and import tax what do you think of winder watchweasol
1 hour ago, oldhippy said:
Something like this is what you need. You can take out the largest fusee springs with this type.
What make is that and how safe are they oldhippy
I don't know the make of that one, that's the style I have, it's similar to the Bergeon one which is still made today.
9 hours ago, wls1971 said:
The only demonstration of a English pattern mainspring winder I can find is this one on a BHI site quite alarming to watch all I can say this man must have the strength of pop eye in his hands note also not a glove in site.
I suggest no emulation of this.
https://www.slbbhi.co.uk/?page_id=2663
Glad i didn't watch that first, might have put me off taking a spring out and buying a winder
Hi Willow   I would say the winder is ok, also the one posted by Old Hippy will do the job but take into consideration the comments by wls1971 and watch the demo. They were all designed to do a job as was the OlliBaker but all require a gloved hand to hold the spring. The Webster pattern has a clamp for the spring barrel and therefore inherently safer. They are all capable of doing the job as long as the required precautions are taken and used responsibly.
Hi watchweasol just watched the video he makes it look easy but i wouldn't trust myself with one of them i definitley would have lost a finger and he is not wearing gloves,
