I have now had two Bulova movements, (10 BTC) and (10BU) have the same issue. If I wind both movements up and gently nudge the balance wheel it will run for about 5 seconds. If during the 5 seconds of movement I keep pressure on the spring via the stem, the balance will keep running indefinitely until I let pressure off of the stem. I have removed both springs, cleaned and lubricated them and re-installed with the exact same issue. At this point I am assuming they are bad springs, although they both appear to be intact and good. Is there something else that can cause this that's unrelated to the mainspring? In both cases I have cleaned the parts and have seen no wheel or pinion issues. Many thanks to all advice.
Remove Balance, take it apart and clean balance pivots & jewels and oil balance jewels (at least).
But since you will have to remove the hands and dial, you might as well clean every jewel.
Edited by Poljot
Ageed ,and don't forget the pallet folk ,as they can be gummed up .Sometimes ,for some reason ,someone lubricates the pivots and they are like glued to the pallet bridge.And will stop a movement on its own.Have come across this problem many times,all it was was the pallet pivots glue to the bridge.
Edited by Graziano
How's the running of the train without the pallets installed? If you turn the crown a few clicks, does it run down smoothly or jolt to a stop?
Background history of the watches? Were they running before you attempted to service them?
From my interpretation of the quoted above you appeared to views the Springs that were in the watch? What color were they blue or white? What did they look like were they a really tight spiral or did it open up quite a bit. Even if they were  set that means there were a really tight spiral you still should Be able to wind them up a little bit and what should run at least for a while not the problem you're having.
Maybe you should explain your cleaning procedure and lubrication procedure? It sounds like a watch that has super friction somewhere between the mainspring and including the mainspring all the way to the balance wheel.
If I take the pallet fork out, all of the wheels freely spin. The watch will fully wind without issue. At the end of the wind the balance will move and stay moving with the pallet forks operating as they should including the escape wheel but only if I keep pressure on the stem as if I were still winding.
On both movements I removed the springs, (white) and they appeared to have a normal expected shape with no damage. I cleaned them both with rubbing alcohol and lubricated with Mobius 8200. None of this changed the issue that is why I am wondering if there is an issue not related to the spring at all. I will try and clean Poljot suggested above. All suggestions are greatly appreciated.
If you're really stuck try installing each wheel in isolation and check that each spins freely with no more than a puff of air from a blower. If they do then build the train up one wheel at a time, testing freedom with the blower after each wheel. If you get to the point where the complete train is installed up to and including the escape wheel, then with the pallet fork and click out you should be able to spin the whole train (including the M/S barrel) in both directions using a puff of air on the escape wheel. Next install the click and wind just one or two clicks of power into the M/S, no more. The train should spin freely, and if you're lucky you should see the escape wheel reverse maybe a half turn before it stops. This systematic approach should help to identify exactly where in the train the losses are occurring, if that is where the problem lies.
Before you install the M/S into the barrel you should try installing the arbor and the lid (empty barrel) and check the end and side shake of the arbor in the barrel. The barrel should spin freely on the arbor, but with minimal end and side shake, any excess of which would indicate excessive wear.
If you get to this point and the M/S is correct and in good order then it's fairly safe to assume that the excessive power loss is associated with the pallet (check pivots which should be run dry and undamaged, pallet stones which should be spotless and not scored, and lubrication), or with the balance pivots.
A quick check for losses in the balance can be made by installing the balance without the pallet fork. From its rest position carefully turn the balance wheel through about 300 degrees of rotation and then release it. Time how long it takes to come to a complete rest, you should be looking at times in the order of two to three minutes or more, and its decrease in amplitude should be gradual and consistent until it stops. If it comes to a sudden stop or comes to rest in much less than a couple of minutes then end shakes, side shakes, and condition of jewels and pivots need checking.
If all the above is good and the problem persists then it's just possible that there is an issue with the escapement geometry (position of banking, position of pallet jewels, height of engagement between the pallet stones and the escape wheel teeth, engagement of impulse pin with pallet fork, roller and guard pin, etc) however, these are things that would have been sufficiently correct for the movement to have performed to factory specs when it was new, and which don't normally go out of adjustment unless someone else has been playing with them, which is a whole other can of worms.
We rely on your eyes to make diagnostics but your eyes aren't seeing the problem yet. Could we have a picture of each of the watches looking straight down set it over the balance wheel. That another picture looking inside ways at the balance wheel. It's amazing how much energy you can lose at the hairspring isn't quite where it's supposed to be. In addition to all the things above but. Sounds like your gear train is free by your own description. So it could be related to the balance wheel.
With no power at all the balance wheel should be very very free to move is it? In other words if you manually with your finger wind it one turn it let it go what happens?
I think that unless the mainspring is badly deformed that is unlikely to be the issue. If the rundown of the train is okay - or at least not awful - most likely problem is in the escapement or balance wheel. Check the hairspring is not hung up on the centre wheel - easy enough to do and easy enough to miss. Also check the hairspring is not out of flat and rubbing something.
I fully let the power down. Turn the barrel by finger, you get a feel of the torque the movement takes to start running . That would give you an idea if you get inadequate torque out of both spring( unlikely).
Next check turning( by spoke) wheels of the train.
Make a habbit of this tests to get the hang of it.
I didn't get to read all said so far, but agree with JohnC.
1-Oscilators grously out of beat wont self start.
2- Bad pivot.
3- Fork pallets badly out of adjustment.
4-No end shake on staff, fork arbout and escape wheel.
Make a habbit of checking the oscilator,
See if pivots jump out of jewel holes as you gently raise one side of the balance wheel.
Good luck
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
    • Seems to still do it through my mobile data, I use an android phone almost exclusively, but I'll double check it. Thanks mark Strange, I'll try my laptop that utilities edge. I've been on site half hour since I got home, it hasn't done it yet. Thanks John
    • At work, I'm on MS Edge, not through chose, on my phone, chrome, no issues with either.
