After having experimented with some very cheap watches I thought it was time to attempt something a little nicer. Bought this silver pocket watch and took it apart. Noticed quite a few of the jewels were shattered so is likely to be beyond my skill set at the moment to restore anyway. Despite that, I decided, probably unwisely, to examine the mainspring and measure it up for a replacement so rendering it useless in the process.
The measurement I have taken are:
  • Height: 2.6mm
  • Thickness 0.2mm
  • Length: 520mm
  • ID of barrel: 16.5mm
  • Type TR
Then I find out there is no replacement to be found in the TR book which I accessed through the Cousins website. Am I not looking properly or have I made a big mistake in assuming a replacement could be found?
Many thanks.
  • Height: 2.6mm
  • Thickness 0.2mm
  • Length: 520mm
  • Type TR
Many thanks.
You can never be sure that the mainspring that is currently fitted is the right one. Check what size is needed for this caliber first, or measure the depth of the barrel and subtract 0.1mm to verify is 2.6mm is right.
Ah, that opens up quite a few more possibilities. The barrel depth is 3.4mm so it can be a considerably wider mainspring as long as I stay within 3.2mm to build in a little safety margin. You are right that the current mainspring almost certainly was not the correct one.
Exactly!
However, 3.4mm seems to be very deep, are you measuring correctly? What is the movement?
35 minutes ago, nickelsilver said:
Cousins lists a GR 6801, 2.60 x 0.20 x 540 16.5, that would work perfectly. It has a normal "tongue end", which will work fine with the hook in your barrel.
If the exact spring cannot be found, in what order of importance would you rate the different parameters? I would have thought that the type, height and ID of the barrel are absolute requirements. Thickness and length less so?
Strength, height, length.
I have measured with the depth gauge of a Mitutoyo caliper, resting the the base on two sides of the curvature, allowing the depth probe to reach the bottom, keeping it as parallel as I could manage.
Right, you are measuring to the top edge - do not forget that barrel lid takes some space also.
2.80 x .205 x 600 x 18 TR- End
GR7002TR
58 In Stock
£7.30
This is probably as good as it gets for TR end from what is available on Cousins site.
GR7002TR
Almost, but not quite. The 18 is too big as barrel ID is only 16.5mm (17mm on the reference sheet linked above so my measurement is likely to be 0.5mm off).
With TR springs being difficult to find, would a DBH not work better than a normal bridle? I am thinking that the hook at least has a hole to engage in?
Do not be concerned about 16.50mm Vs 17.00mm. All it means that you will not be able to push it in, but nothing stops you from using a mainspring winder, or your fingers to install the mainspring. 2.8 is way better choice than 2.6 for your deep barrel.
I have found GR7087 which is 2.90 x .19 x 520 x 16 is stock at Cousins which is probably as close as I will get. Many thanks Poljot and Nickelsilver for your kind advice!
The Generale Ressorts book specs the GR 7070 for this caliber, 2.90 x 0.175 x 500. Cousins has 87 in stock at a whopping 7.30 GBP. Dang, I get my springs directly from GR and they are always 25 CHF and up!
  • 3 months later...
The Otto Frei web site carries mainsprings as well, categorized by end-type, strength/thickness, height, and length.  If you should ever have trouble getting the spring you need at Cousins (which I think would be rare) then Otto Frei is a handy back-up.
Looks like it was made in St. Imier, excellent watch. I wouldn’t worry to much about the jewels I bet you it’ll keep good time anyway. You can change them at a later date ?
  • Similar Content
    • Hello Gentleman, Anyone ever work on this watch before? I've been enjoying this hobby for a while now and have had some decent results.  Am progressing nicely to more and more complicated movements,  but man, for the life of me, I can not figure out how to remove this ETA 7750 from the ring around it.  I've successfully removed the movement and its holder from its outer carbon fiber case, but cannot remove it further. I've removed both pushers and the stem and it, frustratingly,  doesn't simply drop out when inverted.  It also doesn't rotate from side to side within the outer movement holder.. it is stuck fast.   I'm a little embarrassed honestly.   The red arrow points to a line in the movement holder, but it is seemingly one piece and not separable there. I guess they just needed to reduce some outer diameter there. The ends of the minute and chronograph hand extend over the minute marking ring so would that mean that that minute marking ring is part of the dial attached to the movement? I guess I'm asking where does the dial end? Any point in the right direction would be most welcome. I've never worked on this movement before and I am chomping at the bit to do so.  It represents the next challenge in my progression. But obviously cant start until I remove it safely and I'm stumped!
    • Donor movement received. Now waiting for a proper & calm time slot to perform the transplant.
    • Hi Joe, I mean the situation when the escapement can be unlocked when pallet fork is pressed as the guard pin to touch the guard roller. This will be possible if the guard pin is short or the depthing of the escapement is not deep enough. The pallet fork was replaced, but I don't think it was adjusted to work correctly with this movement.  Of course, if there is defect on the guard roller, it also can lead to such problem.
    • Hi everyone, I am new to watch repair and loving the whole process, even some of my fails…maybe. Right now I am looking at purchasing a press for fitting watch crystals, and I was wondering if any of you have had experience with the BMC model (seen in photo) and if you know whether the Robur press dies would fit, or, if not, what alternative dies might as I am having trouble sourcing original ones.   I know that the subject of crystal presses has been a well covered topic here, so I apologies for bringing it up again but I hadn’t found any past threads on this points. Any help on this would extremely helpful. Thanks! Joshua
    • Hi, I just wanted to share the unmistakable quality of a Rolex made in approx. 1990. Cleaned and serviced for a friend using appropriate oils and greases, with Epilame on the parts recommended by Rolex. New mainspring and upper setting and jewel for the minute Pinion (cracked jewel). Run in overnight and then worn on the wrist for a couple of hours to warm. Without any adjustment to the balance weights the watch ran at 0 SPD DU, all positions within +3 and -2. Vertical amplitude after 24 hours of 230 degrees minimum. Watch running at zero seconds per day on wrist when worn 24 hours. Serviced just once before 20 years ago. No need to buy the Microstella regulator tool, not this time anyway 🙂 No scratches or damage caused to screw heads and bridges. All seals replaced and waterproof tested to 60 metres. All good practice for when the time comes to service my own Grand Seiko.
