Check this out
Very nice.
I've seen a couple of instances of copies of this classic spaghetti western watch being offered for sale.
If the original could do what it does in the film, it must have been a pretty spectacular piece of technology given how small it was, how loud it apparently was, how many notes it could sound, and how long the spring for the chimes lasted. I suspect there was a lot of artistic license used.
Loads of artistic license.  Even reproductions of this watch use electronics to reproduce the music.  Clint is 6'4" tall, so the tip of his thumb to the first knuckle is likely to be just slightly more than an inch.  The watch's diameter is smaller.  About an inch; about a size 0.  I have a Waltham that size.  Most musical alarms and repeaters I've seen online and elsewhere have a bit more bulk to them, and they are mostly not very loud.  And the song played is, of a necessity, quite short.  I'm with you, Andy: the watch in the movie would be an awe-inspiring mechanical marvel for its time period, if it actually worked that way, and worth a few kings' ransoms.
    • I read that same article last night  H.  I think epilame is too much headache for me, sources aren't always accurate, some conflicting. Such is the GRAVITY of this situation, Is it ok if i just STICK  to a thixotropic oil 🤣
    • Not sure I follow along. As I stated in one of my previous posts, the epilame will remain intact between rubbing parts as long as the surface is lubricated by oil or grease. Maybe it's just a coincidence, but note how the epilame-treated surface is illustrated in @Waggy's post. It looks like the oil is exposed to a binder (epilame!) so that it can't move sideways.
    • The epilame under the oil will also be removed  Unless the oil makes a barrier between the epilame and the escape teeth 😅 I think i need two strong coffees now 🤣
    • If we use the rub-off epilame method of pallet stones (run dry for a few minutes before applying the epilame) where will the oil go/be transported when it is pushed away from the impulse surface by the escape wheel teeth? Onto the epilame-treated sections of the pallet! Once the oil has been applied/transported to the epilame-treated sections of the pallet where will it then go? Nowhere as the oil will remain on the epilame. So, perhaps the run-dry method defeats its intended purpose leaving the pallet impulse surfaces dry!? If, on the other hand, we do not remove the epilame from the pallet stones where the escape wheel teeth come in contact with them I'd expect more oil to remain where we want it and need it. Yes, I agree, that is the question, and my gut feeling tells me that is exactly the case. Epilame was created to have an adhesive trait and the oleophobic property is just a side effect.
    • Might that be the viscous nature of oil resisting gravity H  ,  we have been comparing water and hydrophobic surfaces which are similar in principle but water is much less viscous than oil. I guess what we trying to discover is if epilame also has an adhesive trait as well as being oleophobic. Plus the oil dropet has very little mass for gravity to work on, like watching tiny water beads that can grip onto vertical glass until they are connected together to increase their mass then run down. Gravity isn't the only factor at play when oil is placed on pallet stones. The oil receives a lot of bashing that may push it out of position ? Thinking about it if the oil stays in position for 10 minutes enough time for the escape wheel to scrape off the epilame , then  a walled in lubrication has been achieved,  the epilame is no longer beneath the oil ( possibly mixed into the oil )
