Balance wheel
Willow
I just thought how bad it is out of shape and when a secure it with the pin it would not be possible to get it in beat am i wrong. Do thing it will be ok like that. One other thing where the spring is secured what is the purpose of the notch just before the hole
Edited by Willow
add another question
Hi Willow   the balance spring looks cabable of being re formed, being a clock they are that bit more ameanable to manipulation. So with care saveable and if done whilst attached to the balance it should be in beat,  If you remove the spring for repair then mark the balance hub where the split is in the collet so as you can re attach the spring in the same location.
Hi Willow  best thing to do is to mark the spring position on the balance an then remove it, working on a white/pale card re form the outer curve on the same arc as the rest of the spring using tweezers  or balance spring tools. another possible is to make a template photograph the spring on the card and then print it now you have a guide to work to in the shape of the outer coil.      good luck.  I sounds more difficult than it is in reality.
Hi all working on this tameside clock, and noticed what looks like a washer holding the clip spring on, my concern is there is a crack running through the washer (see Photo) its holding the clip on fine and if i take break it off will i have trouble  replacing it and what my options are, thanks all
    • Yep, i pulled that up as well when i was looking,  there is definitely parts out there if you are prepared to go out and find them.  I watched that video years ago, I'm not so sure about probing the coil like that. If you are going to touch the coil use the side of the probe or at least shape a nice round end to it.
    • Hi and welcome to the forum.   As you are already familiar with watches the attachment you may find useful Witschi Training Course.pdf
    • I saw this listing from Australia this morning on Ebay, it might be your only option, good luck.... https://www.ebay.com/itm/145735044565?itmmeta=01HWCRFPEYDDTCXYCRX7ESQH3K&hash=item21ee7c4dd5:g:f2oAAOSwaMhmI5tq&itmprp=enc%3AAQAJAAAA4PzZAWzJj0HOwVM7Xl6qUqGIYly3BvZhzNybkxWf8GJYkKwVh0SpeZ0XYBmoZyjaboPOlJYzdY9svwhQXfR7V%2BiMApTEYFLvJcs8FxTzy1VFCBLR8ADc7V89%2B%2FYvQKdks2KDNNEqAFZN0Hni9zQG078wKL34x0eRK%2Fu843fYdH%2FVIAiOZ5%2BbOmySNdu%2Bv4cSemywC%2FWfaiI%2Fj5D3YWk2PaySdPfu7lUaMadcyhmHZM6l6NllJd1eK%2BdblkJD98pTzVuxRDne5AQaCYawls%2FaoQK9B7epV%2B87TIbD9Ulr4qdC|tkp%3ABk9SR-rnvpjjYw
    • Hi. In the picture not only does it depict that the wheel is bent but also the plate or is that due to th angle of the picture.  Already received very good advise so I will butt out.
    • welcome, sounds like you are on your way so far, you also might be able to help with gold/plated case repair for some .....
