Timex Sprite 1975
ForkBoy
8 hours ago, Watchtime said:
First check which movement is in your watch. It could be a M24 for example...You check the movement on ranfft.de and you will find the dimensions of the hands you need and order those on Ebay
no need to check, I can tell you that is a model 24 movement. But, not just any model 24 hands can be used. This is because the Sprite is a small dial size and the hands from a Marlin will be too large.
