New to this forum, and to any forum actually, so I'm doing as suggested and saying hello!
Obviously I haven't read everyone else's introduction but perhaps I ended up here via a different route to most. I've always had an interest in precision made objects and watches definitely fall into this category. Like everyone here no doubt, I have more than a few watches, and I've always been searching for what I consider the perfect watch. Well I thought I'd found it, at least for me, in a Citizen ladies dive watch, commonly referred to as a EP6000-07H I believe. I appreciated it so much I thought, given they're becoming more and more rare to find, I'd see if I could find another.
And I succeeded, partly. Unfortunately this second one was broken - I guess a common break in that the crown screw thread had broken off. (It was very cheap for this reason and I knew this when buying it.) So I thought, well I'm interested to see inside so I gained a cheap watch back tool and opened it up. Then I thought, I wonder if and how it differs from my original watch. So I opened that up too. I suspect you know where this is going now - five minutes later I had two broken watches ?
So I ended up reading advice on this site, and have got the mechanics of the latter working in the former, whole body through learning from people's words of wisdom!
Now I'm wondering what else I can do - how to successfully charge the evidently weak batteries? Does Citizen (or anyone) fix watches it no longer manufactures? Can I remove the mechanics solar front to see what's behind _and_ fit it back again?? The little things can occupy the mind, can't they!!
Gil
Welcome to this forum. I'm a fellow watch killer.
EP6000. Is that an Ecodrive? Ecodrive watches use a rechargeable battery that needs to be replaced when it reaches it's end of life. Originally, a gold foil capacitor was used, then over the years, rechargeable batteries replaced the capacitors, probably due to cost. So sometimes it is still called a capacitor or even a chemical capacitor.
You can check if it's a battery problem by putting the watch under a bright light for a few minutes. If it starts running again, that confirms the diagnosis. I think most competent repair centres can replace a rechargeable battery.
Welcome to the forum.
No shortage of electronic and electrical engineers on this forum to explain how echodrive solar panel loose efficieny and correct me.
In echodrive dial plate is a panel of solar cells that trap some electric charge off of photons( light) with a nominal life expectancy of 15-20 years,  so either the panel or capacitor or combination of both can be the issue in your watch.
Good chances are that your watch will keep on running if you keep it under intense light, but exposure to light during normal use would no longer be adequate.
If you can find and replace the capacitor with a regular cell of exact same output, your watch would be as good as a regular not-rechargeable quartz watch.
As for trying to repair, I am affraid you will end up with a bunch of used watches with dead solar panels.
Regs
Joe
    • I've been on a ESA 9154 kick lately with this being the latest. A funkalicious 1970's Elgin Electronic with a brown and orange earth toned dial in a big old hunk of steel. Just like the last one this one runs from about -2 to +2 in 5 positions as it seems to be easy to dial these 9154's in.
    • I wonder what the theoretical size limit is for both a quartz and mechanical movement?
    • I'm currently working on a Citizen 4520 movement. This has to be the smallest and weirdest quartz movement I've ever worked on. Firstly, it's small. Really small. Here's a picture of it next to a LR44 battery for comparison.  And unlike conventional quartz movements, the construction of this movement is really weird. The moment I took off the top plate, the rotor and 1st wheel are exposed. The PCB is right on the bottom plate. There are no dial side components and cover plates. Everything goes in from the rear. Not sure if I'm able to fix this watch. The old battery leaked and there are battery juice crystals everywhere. And there is a 1 uA constant leakage current, which will drain the tiny battery in no time. But at least there's still a pulse and the rotor twitches.
    • Afraid this is where it could get down to old school adjustment and observation. There are pallet setting tools..but the calibrated ones aren't cheap. The observation holes in the plate will allow you to see if you have one or both stones hanging up/ not engaging on a tooth, That would ofcourse require you to disassemble, heat/move the jewel in/out as required..by eyesight and experience. It's truly trial and error until you get close enough that you could make small adjustments with the banking pins until they drop to the lock freely. You can use a Potence tool to help hold the rok in place during reassmbly. Here's a pic of one...made with a piece of old 18s mainspring You just fold over a roughly 2 inch piece, then file a slot on the end that engages the pallet fork arbor
    • It least you know what to order.
