My First Cylinder Movement
Deggsie
Hello all, hope you are all keeping well?   Ive just cleaned and reassembled my first cylinder movement, it’s a 1900 (ish) Fontainemelon, 13 Ligne.  Can someone tell me if I should lubricate the escapement teeth please, and what should I use - I was thinking moebius 9145 Grease?  Or should they be Left clean and dry?   Thanks in advanced
Deggsie
On 12/10/2020 at 11:29 PM, nickelsilver said:
Yes lubricate the teeth, normal escapement grease is perfect 9415.
Thank you NickelSilver.   I trust your reply over one other I found, saying use vaseline and fill the hollow of the staff ?
Have a good weekend and Happy Christmas to all.
1 small dot of 9415 applied to every 3rd tooth, installed new main spring, and she started up beautifully.   Did need just a slight swing to get it going after a few clicks, but I understand this is normal as the cylinder escapement design doesn't allow for self start up like the Swiss lever design?  For a 100 year old watch I am just happy to have it ticking again, and not too concerned yet about its time keeping abiity.
Regards
Deggsie
Regards
Deggsie
I suppose the watch case is far from being air-tight. I would try to place as little oil as possible to avoid particles of dust being attracted to the surface of the escape wheel teeth. Otherwise, very soon, your watch will stop or, worse, it will turn into a "grinder" very quickly (depending on usage of course). I agree, would not be concerned about time-keeping ability. No need for the timegrapher :-). Would be nice to see a photo of your 13''' movement.
    • Hello and welcome from Leeds,England.  Ask away.
    • What cutter are you using can you video the action
    • if you're trying to keep track of conversations scattered all over the message board emails are an absolute must.   looking at the bell icon on the top of the page versus the emails today it looks like I got the correct amount of emails. So making some minor change based on the one of the images up above I started getting notifications again. But at times I still have a suspicion that something isn't quite right. I have some feeling that the message board may delay sending emails until something so seems to be a long delay between when you get your emails just a weird feeling things aren't quite right oh  and then even though I do seem to be getting emails I no longer get notifications of personal messages I don't find that out until I arrived at the message board where I'm pretty sure I used to get notifications of those two. So something is definitely changed on the message board. then for everyone not getting emails you do want to check your spam folder. I have found that sometimes were open up an email the system I use warns me that it thinks the email is evil and bad and I have no idea why he thinks some of the emails are and some are not. But this is actually the program I use not the email system which also has a mind of its own as to what it considers spam so you should always check your spam folder.
