...and hi all x2
Also in the vintage lot was a Seiko 5 7009A movement with a hazed or deteriorated crystal. Anyone seen these with the silver ring on them like this? Movement itself just needs a service I think so I'm going to attempt to get it running.
Wow! My cats Rodico hairball. And I don't have a cat...
53 minutes ago, MechanicMike said:
...and hi all x2
I could be wrong, but all you need is Tension (Armoured) Ring - Standard Ring - Chrome Colour - Sternkreuz ATC
https://www.cousinsuk.com/product/standard-chrome-ringed-glass-atc
So they do exist. I was about to think it was some sort of skinny Chapter ring. In my short time doing this, never seen them before. Are they to tension the fit? Or strengthen the acrylic?  Interesting....
If there are no micro cracks in the acrylic, then polishing the crystal using Duraglit wadding usually restores them to near perfect condition......
Edited by JohnD
8 hours ago, aac58 said:
You can probably find the exact Sternkreuz crystal you need searching by the Seiko model number in this page: https://www.cousinsuk.com/category/filter/seiko-case-parts
STK didn't made dedicated crystals for all Seiko models. Only for the few ones that they deemed worth to offer an alternative, many decades ago. A generic crystal can work just fine, ordered by size.
24 minutes ago, Bodo said:
What's the case reference of the 7009?
That to allow searching the Seiko P/N on Cousins, jborel, Boley etc public references. Sometime you can find the part as NOS on Ebay etc, but often the asking price will be 2 or 3 times what the watch is worth.
The best recommendation is to just polish the crystal, which is very easy on acrylic like that
That's why I said "probably". I like the SK quality, but everyone can choose what they like, I was just trying to help. I've found a SK crystal for 90% of the Seiko's I've search for, I'm not sure the watch model in this case is 7009-340x, I really doubt it is despite it is the dial model.
Edited by aac58
Searching with Seiko case ID should be definitely your first step. Sometimes you get lucky ... and sometimes you don't.
When you don't, this page plus your measurements will find you the crystal you need:
https://www.cousinsuk.com/category/watch-glasses
7009-8810. I have them looking. No answer so far.
8 hours ago, Poljot said:
I've tried: "No items matching or containing '7009-340' are listed in our database. Please check your lookup for mistakes and re-submit."
Same answer I got. So I gave them 7009-8810. See what they say. In the meantime, I ordered a Stella Ever-tite with tension ring at 33.1mm from Esslinger and I'm polishing like crazy to see if I can get this weird white dust-like stuff off the existing crystal.
Mad polishing going on right now...
8 hours ago, MechanicMike said:
7009-8810
The Sternkreuz crystal code for that watch is XAC 311.664
Edited by aac58
  • Thanks 2
Available from 'Cousins' quite cheaply.....
  • Thanks 2
Yep. Just ordered a couple minutes ago. Thanks guys.
I am still waiting for my orders placed 5 and 3 weeks ago. Good luck!
Strange, I've always got my orders within a day or two...
oh man...
found, or finding out, this is very true, indeed. I wonder if they do this intentionally to drive us amateur hobbyists nuts? Same with their movement numbers, model numbers, and every other number combination they can think of...
