Original 2824 or 2824-1 assembly
The base is the same in variants of the caliber, I take pictures as you turn down specially of the date mech that you are not familiar with, this will not only help during assembly it also is a gallary to refer to and show how things were, where you might come face an issue,  if a datasheet exist,  it will be found.
Tell as much as you know of the history, issues etc.
Good luck.
Good luck.
Unfortunately, like an idiot I didn't document during disassembly and it was too late by the time I realised it was an earlier variant.
I've circled the area I'm having trouble with, it's where the calendar click would usually go on a 2824-2.
No problem, just good to make a habbit of.
Now internet acting up so can't give you this link dierctly,but.
Go to search function, search
ETA Cal 2824-2 (17 jewels) disassembly/ assembly by vWatchie dated jun 10,2119.
Excellent walkthrough.
Good luck.
Good luck.
Thank you for that, just found that thread and looked through his disassembly photos, unfortunately it's a slightly different date change mechanism on the movement I'm working on, can't seem to find any pics online at all!
Good luck.
oops 2019 not 2119.
Ok, show and number peices of date change train, you will be shown where each pieces goes.
4 minutes ago, Ageorge1988 said:
These original 2824 docs say it's part number 2556 for the date wheel, is that in place of 2555?
I can't work out how the jumper spring (part #2575) fits.
2575 fits behind 2576 to push it into date disk "detent".
A picture worth a thousand words, isn't it.
I've got 2576 in the right place I think, I tried to fit 2575 where I've drawn in blue pen, it was tight but went in and then snapped so I've either put it in the wrong place, been too heavy handed or the part was worn as it's from a circa 1970's rotary.
I've ordered a replacement part from ebay.
I've now got a replacement spring (2575) if anybody knows how to install it?
    • Thanks everyone for your helpful replies. I think between us we’ve worked out what’s going on. Next job is to have a proper look at this great wheel assembly, see if I can remove the clip and the friction fit pinion, give the bits a good clean, then put it back together with a bit of blue grease. I’ll also get the pallet fork under the microscope to see if it’s ok or been damaged.
    • The cannon pinion (be it conventional style or what you see in this movement) should slip on its arbour so the hands can be set independently without affecting the gear train.  If there is too much friction between the cannon pinion and the second wheel, turning the hands to set them backwards can sometimes force the escape wheel teeth to overrun the pallet stones, creating the behaviour you describe. The train is running in reverse when this happens.  This can often chip the pallet stones. I’d say at least half of the watches I’ve inspected with very tight cannon pinions had chipped pallet stones. Hopefully this isn’t the case with your watch.  I’m not familiar with this movement but you need to get the friction in the cannon pinion adjusted correctly.  Hope this helps, Mark
    • Pallet fork was in. I’d had the movement running ok, and only removed the balance to flip it over and install the keyless works and date mechanism. The pallet fork wasn’t locking the gear train when hand setting - it was oscillating as the escape wheel rotated. This may have been in one direction only - can’t remember.
    • Hi   Find attached parts/repair notes for the JLC 911,  might be useful. JLC_JLC 910, 911.pdf JLC_JLC 910, 911 Repair Notes.pdf
    • Hello and welcome to the forum Dan. Used to know Middlesboro quite well, that was twenty years plus ago. Attached a little reading to get you started. TZIllustratedGlossary.pdf
