felsa 4007 barrel set up
gary17
Hey guys
has anyone done a mainspring change in one of these.  As i say above it is a felsa 4007.
The first 3 pics show the top of the barrel, See the hook in pic 2. That then goes over the piece sticking up in pic 4. But i am finding it virtualy impossible to hand wind the mainspring into the barrel pic 4 the sticky up thing gets in the way. The piece in pics 5 and 6 ( it acts sort of like a arbour) it has no hooks and no use except to center it when it goes into the watch. The arbour does not turn. The part of the barrel with the hook. ( see pic 1,2,3) turns via a wheel attached directly to the  intermediate wheel.
Any way back to my question. Has anyone come across this set up before and if yes howq do i go about getting the spring back into the barrel.
cheers
garey
unhelpful answer it kinda looks like a weird version of a waltham pocketwatch mainspring barrel. Except that barrel does not have the center part that you having a problem with. If you can't hand wind it in then you're going to have to find a mainspring winder.  or a new mainspring and just push it out of the ring.
  • 2 years later...
On 11/11/2020 at 8:56 PM, gary17 said:
Hey guys
cheers
garey
Hi, did you ever solve this? What did you do?
    • Usually the coiled spring contacts the piezo sounder and the finger spring is the ground.
    • So I checked with my friendly local lab supplier and they can supply the following in 2.5 lt bottles: Tetrachloroethylene (B-Dip) - approx £65 Trichloroethylene (one-dip) - approx £43 n-Heptane 99% (Essence of Renata) - approx £35 Hexane - approx £45 I can't import or buy locally the 'real' products, hence the raw chemicals above. What do you think would be my best option? I'm edging towards Trichloroethylene - I know there are greater health risks, but given the very small quantities used for each treatment and 99.99% of the time it will be sealed in a jar, I think any risk is vanishingly small? This is mainly due to its assumed superior cleaning properties, or from the experience of this group, is the extra cleaning noticeable compared to its safer alternatives?
    • Unfortunately after much investigation, apparently the coil has been discontinued! Shall I get my service guy to try the solder or the conductive paint? 🎨 Final recommendation please🙏
    • Here are the pics of the bridge. Looks correct, but as soon as I screw on the rotor, the watch stops. Video here: https://1drv.ms/v/s!ArG5E62RGctxjokY5ws85BzuJLVakA   Pics. Might have figured it out. I have been working on this watch for a while and since I got it as a non runner in a terrible shape, there was no guarantee that parts were proper. I think the main screw that was used on the rotor was too long, so it was stopping the main train. As soon as I fished out a much shorter and larger headed screw, things were good again. Please celebrate with me.
