Danish Wall Clock
Marty
Good evening all
I bought this clock at auction today, i didn't realise that it has an alarm function until i looked at the movement. Is this type of clock called a postman clock. Something that's puzzling me is how the weight for the alarm attaches to the alarm mechanism, it's hard to see but between the copper plates on the 4th and 6th picture there are steps somewhat like used on a click mechanism i assume it must wind something like on an 30hr clock as there is no other way to wind it. Any thoughts would be most appreciated.
Marty
Good Morning
Thanks for you replies, at first i thought the crown wheel would be chain driven but got an eye glass on it and there is remnants of some sort of cord/rope.
I did wonder if something was missing but there is a slot cut in the base board for the rope on the time side and two holes for the alarm side, the distance between the holes is the same as the diameter of the the "drum" behind the crown wheel, i was wondering if a rope/cord is held in place just by friction !!
Bought at auction on a whim £30 ish
Again thanks for your replies
Marty
I have been looking around on the net but I can't find what I really want. What you have said makes sense as I said that wheel is part of an alarm. I have marked how the alarm would work in red. imagine that wheel rotating and hitting against that steel part that juts out follow the part up and you can see an arm that arm at the end would hit a large bell the sort of bell on a longcase clock. The pulley marked green would have a rope or chain on it to wind it up. I now think this movement could be part of a Lantern clock in which case it will be English.
Hi OH
Thanks for taking the time to help, i have attached a couple of pics of the case in came in, it's in a bit of a state, the second shows the "base" board which shows where the alarm rope passes through, i thought maybe the rope just loops over the alarm mech with a knot tied to stop it passing through the hole, i think this would be the reason for two holes instead of a slot as is used for the time side.
Your clock is what is called a Hook & Spike hooded clock with alarm. Unfortunately you only have part of the movement.  Here is a link about these clocks. I'm also enclosing a photo of one that shows the alarm like your alarm fitting. I have pointed out one of the spikes on yours. Both would be jammed into the wall to prevent it from moving when the clock would need a wind up.
https://www.brianloomes.com/collecting/hookandspike/index.html
    • I loved his explanation of a teardown 😅 Ex military Richard Perrett, pretty knowledgeable guy.
    • I also see a bit of danger for the wheel, at least you have to keep away from it and may get a too thick rest ring. My rest rings are about 0.05 mm. Better way would be a grinding wheel touching the staff with its circumference. Frank
    • Not easy to find this one everywhere,  so it depends where you are located. Joining it back together might be possible, i have silver soldered mild steel before even with traditional plumbers lead and its a pretty strong joint, but bere in mind this is only 1mm diameter.  The join would need to be very accurate,  it not something i have heard of anyone trying before. The part no 401 is the swiss code number and relates to watch winding stems in general
    • Thanks everyone for your helpful replies. I think between us we’ve worked out what’s going on. Next job is to have a proper look at this great wheel assembly, see if I can remove the clip and the friction fit pinion, give the bits a good clean, then put it back together with a bit of blue grease. I’ll also get the pallet fork under the microscope to see if it’s ok or been damaged.
    • The cannon pinion (be it conventional style or what you see in this movement) should slip on its arbour so the hands can be set independently without affecting the gear train.  If there is too much friction between the cannon pinion and the second wheel, turning the hands to set them backwards can sometimes force the escape wheel teeth to overrun the pallet stones, creating the behaviour you describe. The train is running in reverse when this happens.  This can often chip the pallet stones. I’d say at least half of the watches I’ve inspected with very tight cannon pinions had chipped pallet stones. Hopefully this isn’t the case with your watch.  I’m not familiar with this movement but you need to get the friction in the cannon pinion adjusted correctly.  Hope this helps, Mark
