het guys
anyone know were you can get a decent watch case. Not a named maker. Just a decent watch case .Don't need a strap just a simple case.
I have a nice movement i would like to wear.
cheers
gary
Always plenty to choose from on the bay...
Sub style case (complete) that accepts the Seiko movement is like $35.00 as an example.
And you can get aftermarket crown tubes and unbranded crowns for Rolex for very little (7030 tube and 703 or 704 crown), and they will provide a good seal at the crown for you.
What you would need to determine is the stem height of the movements you want to use and cross that with the ubiquitous 2824 for example, or other "popular" movements, and see what will work. Making the movement ring is easy enough, if needed but stem height can be tricky unless you can get taller cannon pinions and hour wheels etc. to compensate for raising the dial off the movement.
Unfortunately a lot of the vintage/NOS cases that are not from major "makers" are generally brass, or worse, with chrome plating. Solid stainless cases that are vintage are not easy to find for cheap money.
That would probably go well into a Datejust style case. Does it have a date complication?
You would probably need to make up a movement spacer ring- what is the movement size/diameter?
15xx movement is 28.5mm diameter and (overall) height of 5.75mm for the no-date to 7.03mm for the day-date 1556
Wow. 30.8 is a big'un. Casing diameter of the 3135 is 28.1 (movement listed as 28.5mm as the 15xx) so a "sub" case would have to be opened up nearly 3mm to fit. There should be enough meat there but I think the caseback threads will be gone...
Perhaps a Panerai (style) case? Of a Fleiger case for the Unitas 6498 (which is 36.6mm so you'd need a ring and custom dial) https://helenarou.com/43mm-laco-luftwaffe-fliegeruhr-watch-case-4-hamilton-434917921923945.html
Otherwise you'd have to wait for the right original case to come along.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
